03-22-2020, 09:57 AM | #1 |
steel wheel help
Does anyone know where I can buy a new set of 16 x 8 or 16 x 10 / 8 lug wheels without powder coat? I want a stock type wheel, so I can use the factory dog dish hubcaps.
03-22-2020, 07:14 PM | #2 | |
Re: steel wheel help
Any reason why you want to avoid powdercoated wheels? The two sets that I've purchased are wonderful, and bare steel wheels would require some sort of protection either way. Might as well have the factory do the application.
1980 K10 Suburban Silverado, original 350 w/Qjet swapped to 406sb, TH350C swapped to TH400/205 |
03-22-2020, 09:12 PM | #3 |
Well, I want them in white and I have no experience in painting over powder coating, not even sure it's possible?
03-24-2020, 11:32 PM | #4 | |
Just scuff the areas that you want to paint, hit it with epoxy primer, then whatever color you want. If you use an epoxy like the PPG epoxy you can shoot the BC/CC the same day, some others like Tamco's epoxy you have to wait a day. Painting over powder coat is a great way to protect those hard to get at shapes like a wheel.
Sent by the random thoughts from the voices in my head... |
03-25-2020, 08:29 AM | #5 |
Powder coat wasn't around the last time I picked up a gun, still have my Binks #7 hanging on the wall. ( don't laugh) Thanks for clearing that up!
03-25-2020, 01:22 PM | #6 | |
If you are in Northern California, you could bring them over to my house and I'll shoot them, I even have the epoxy as I buy it by the gallon. Of course you'll have to do the prep!!
03-25-2020, 08:42 PM | #7 |
I have 2 ol’ number 7’s hanging on the hook. That is all I ever used after learning to paint with one 40 years ago....guess we are in the same club
03-25-2020, 11:40 PM | #8 |
I had a bout with cancer 30 years ago, doctor recommended staying away from body work. I took his advice and had no issues since, next scan is in April. I better forget the dog dish idea and buy chrome.
03-23-2020, 06:40 AM | #9 |
They can't powdercoat in white? I think the only way to get wider wheels is to buy the custom ones from Wheel Vinitque.
76 Chevy K20 76 GMC K15 77 Chevy C10 77 Chevy K10 |
03-23-2020, 08:20 AM | #10 |
I've looked around quite a bit, and haven't found any in white., black must be cheaper to produce. How wide are the stock rims? 7"?
03-23-2020, 01:24 PM | #11 |
I think most are 6" or 6.5"
03-23-2020, 03:01 PM | #12 |
I would contact Wheel Vintiques and speak to them about what you want/need. They have the wheels you want (8 lug 16x8) and I'm pretty sure they can just primer them and ship so that you can then either paint or powder coat them.
Wheel Vintiques: 1.877.458.2412
66 GMC Suburban Custom 66 Chevy K10 Suburban |
03-23-2020, 11:12 PM | #13 |
Nope. I did just that last year and they only come in black. It's because that's the arrangement they have with thier Chinese supplier. I have no respect for Wheel Vintiques.
03-23-2020, 11:25 PM | #14 |
I wasn't aware Wheel Vintiques stuff was made in china, I won't be buying from them. Looks like I'll end up going to an aluminum or chrome spoke wheel, might get lucky and find a USA made wheel.
03-24-2020, 11:09 AM | #15 |
Other potential options:
http://www.stocktonwheel.com/ http://www.petepaulsen.com/home.html Both are located in the valley in CA.
03-25-2020, 08:35 AM | #16 |
Summit doesn't sell them? I could have sworn I saw a some there looking for wheels...time to double check....
03-25-2020, 10:33 AM | #17 |
I believe some factory 8 lug wheels were 7" with the nubs also
California 65 GTO---Texas 64 burb 283 ---Oklahoma 67 CST SWB BBW wood bed 327 2004r---New Mexico 72 k10 350 350 auto---Georga 72 short step project |
03-25-2020, 11:24 AM | #18 | |
I've got wheel vintiques 16x10 rims. They're black. I was told after-fact that WV could have special ordered them in white. True or not, I don't know.
1987 C6P V20 truck, 2010 LMG 5.3, AFM delete, 2010 Camaro exhaust manifolds, 1997 nv4500, 1991 np241c, hydroboost, 2005 14bff axle & driveshaft, drop-n-lock gooseneck, 4.10 gears, stock suspension, rims, and tires. Still a work in progress. Any questions or suggestions are welcome! |
03-25-2020, 12:17 PM | #19 | |
GM's center hole is smaller but they are interchangeable.
03-25-2020, 01:17 PM | #20 |
my notes from a few years ago..
http://www.wheelvintiques.com/ Javier 800-959-2100 ext. 625 81 & 82 series 8x6.5 pattern only option [11 5/8” wheel cover] http://www.wheelvintiques.com/wheels...ack-8-lug.html http://www.wheelvintiques.com/wheels...ug-chrome.html custom offset $25 ea custom paint $50 ea [powder coat white] 6 week delivery made to order in house and numerous accounts of Ford 16x7 working just fine.. I actually have a couple of sets but can't even get them painted with all the rain here in 'sunny' ca
I started out with nothing - and I still have most of it |
03-25-2020, 06:10 PM | #21 | |
03-25-2020, 01:23 PM | #22 |
Active Member
Ford E350 rims are 16x7, some will hold the stock Chevy/GMC dog dish hubcaps and some only take the larger 16" hubcap. I put a set on a 1977 K20 I sold three years ago and have another set for my current 1978 GMC K25. both sets I have would not take the dog dish hubcaps, bet in both cases I am fine without any.
The stock GM rims were 16x6.5 for the 1980's square bodies. |
04-01-2020, 02:03 AM | #23 |
As Killer Bee mentioned WV will custom paint most basic colors. But they don’t offer free shipping like Jegs or Summit does. Plus add the extended lead time.
I had em blasted and powder coated white by Les Schwab for $40 a wheel.
"Sweet Pea" 1975 Cheyenne 20 http://67-72chevytrucks.com/vboard/s...00#post8477900 "Bourbon" 1975 Suburban ScottsdaleSOLD https://67-72chevytrucks.com/vboard/...49#post8769049 ”Otis” 1970 C10 SWB -SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=762766 ”Chebby” 1962 Impala LS/TKO-500 http://www.pro-touring.com/threads/1...2-Impala-Build |
04-01-2020, 05:54 AM | #24 |
Old Heap Driver
I've painted 3 sets of powder coated wheels from Wheel Vintiques. Used a red 3M pad, single stage, and a cheap spray gun, they came out slick and shinny.
_____________________________ Bryan '99 Silverado 1500, 4.3, 5-speed, reg cab, short bed '50 Chevy 2DR Hard Top, 350/350, M2 Front End, 3:08 gear, cruiser. '40 F**d Sedan, all Chevy power, Heidt's front end, TCI rear, nice driver. |
04-01-2020, 07:13 AM | #25 |
That powder coat on the Wheel Vintiques steel wheels must be just a primer. It has no gloss to it and it scratches through with ease. If they didn't say it was powder coat I would not believe it was. Coarse sandpaper cuts straight through to metal with ease, like a single stroke. It sands off better than most spray bomb paint.
If you want USA wheels you can get original GM wheels widened. The guy who bought my Highlander K/20 sent out a set of GM wheels (hub centric) and had them made into 17 x 9s. It ain't cheap, but it also ain't Chinese
