Old 03-22-2020, 09:57 AM   #1
3x2GTO
steel wheel help
Does anyone know where I can buy a new set of 16 x 8 or 16 x 10 / 8 lug wheels without powder coat? I want a stock type wheel, so I can use the factory dog dish hubcaps.
3x2GTO is offline   Reply With Quote
Old 03-22-2020, 07:14 PM   #2
SilverMiner
SilverMiner's Avatar
Re: steel wheel help
I almost pulled the trigger and sent a link to Wheel Vintiques at Summit Racing, but then my reading comprehension skills finally kicked in and I realized you want wheels WITHOUT powdercoat, which don't appear to exist readily for sale.
Any reason why you want to avoid powdercoated wheels? The two sets that I've purchased are wonderful, and bare steel wheels would require some sort of protection either way. Might as well have the factory do the application.
1980 K10 Suburban Silverado, original 350 w/Qjet swapped to 406sb, TH350C swapped to TH400/205
SilverMiner is offline   Reply With Quote
Old 03-22-2020, 09:12 PM   #3
3x2GTO
Well, I want them in white and I have no experience in painting over powder coating, not even sure it's possible?
Old 03-23-2020, 06:40 AM   #4
cadillac_al
They can't powdercoat in white? I think the only way to get wider wheels is to buy the custom ones from Wheel Vinitque.
76 Chevy K20
76 GMC K15
77 Chevy C10
77 Chevy K10
cadillac_al is offline   Reply With Quote
Old 03-23-2020, 08:20 AM   #5
3x2GTO
I've looked around quite a bit, and haven't found any in white., black must be cheaper to produce. How wide are the stock rims? 7"?
Old 03-23-2020, 01:24 PM   #6
I think most are 6" or 6.5"
Old 03-23-2020, 03:01 PM   #7
Southcity
Southcity's Avatar
I would contact Wheel Vintiques and speak to them about what you want/need. They have the wheels you want (8 lug 16x8) and I'm pretty sure they can just primer them and ship so that you can then either paint or powder coat them.
Wheel Vintiques: 1.877.458.2412
66 GMC Suburban Custom
66 Chevy K10 Suburban
Southcity is offline   Reply With Quote
Old 03-23-2020, 11:12 PM   #8
SunSoaked
SunSoaked's Avatar
Nope. I did just that last year and they only come in black. It's because that's the arrangement they have with thier Chinese supplier. I have no respect for Wheel Vintiques.
SunSoaked is offline   Reply With Quote
Old 03-23-2020, 11:25 PM   #9
3x2GTO
I wasn't aware Wheel Vintiques stuff was made in china, I won't be buying from them. Looks like I'll end up going to an aluminum or chrome spoke wheel, might get lucky and find a USA made wheel.
Old 03-24-2020, 11:09 AM   #10
Southcity
Southcity's Avatar
Other potential options:
http://www.stocktonwheel.com/
http://www.petepaulsen.com/home.html
Both are located in the valley in CA.
Old 03-24-2020, 11:17 PM   #11
3x2GTO
I remember Stockton Wheel from way back, didn't know they were still going, probably my best bet. Too bad GM never made a 16"x 8- 8 lug rally wheel. Thanks for posting.
Old 03-24-2020, 11:32 PM   #12
EricU
You most definitely can paint over powder coating.
Just scuff the areas that you want to paint, hit it with epoxy primer, then whatever color you want. If you use an epoxy like the PPG epoxy you can shoot the BC/CC the same day, some others like Tamco's epoxy you have to wait a day.
Painting over powder coat is a great way to protect those hard to get at shapes like a wheel.
Sent by the random thoughts from the voices in my head...
EricU is offline   Reply With Quote
Old 03-25-2020, 08:29 AM   #13
3x2GTO
Powder coat wasn't around the last time I picked up a gun, still have my Binks #7 hanging on the wall. ( don't laugh) Thanks for clearing that up!
Old 03-25-2020, 08:35 AM   #14
b454rat
Summit doesn't sell them? I could have sworn I saw a some there looking for wheels...time to double check....
Old 03-25-2020, 10:33 AM   #15
67swb72klb
67swb72klb's Avatar
I believe some factory 8 lug wheels were 7" with the nubs also
California 65 GTO---Texas 64 burb 283 ---Oklahoma 67 CST SWB BBW wood bed 327 2004r---New Mexico 72 k10 350 350 auto---Georga 72 short step project
67swb72klb is offline   Reply With Quote
Old 03-25-2020, 11:24 AM   #16
kipps
I'm told that the widest stock-type rims available from a junkyard are some Ford van rims at 16" x 7". They are said to fit Chevy hubcaps.
I've got wheel vintiques 16x10 rims. They're black. I was told after-fact that WV could have special ordered them in white. True or not, I don't know.
1987 C6P V20 truck, 2010 LMG 5.3, AFM delete, 2010 Camaro exhaust manifolds, 1997 nv4500, 1991 np241c, hydroboost, 2005 14bff axle & driveshaft, drop-n-lock gooseneck, 4.10 gears, stock suspension, rims, and tires. Still a work in progress. Any questions or suggestions are welcome!
kipps is offline   Reply With Quote
Old 03-25-2020, 12:17 PM   #17
67swb72klb
67swb72klb's Avatar
That's what I was thinking also.
GM's center hole is smaller but they are interchangeable.
Old 03-25-2020, 01:17 PM   #18
Killer Bee
Killer Bee's Avatar
my notes from a few years ago..
http://www.wheelvintiques.com/ Javier 800-959-2100 ext. 625
81 & 82 series 8x6.5 pattern only option [11 5/8” wheel cover]
http://www.wheelvintiques.com/wheels...ack-8-lug.html
http://www.wheelvintiques.com/wheels...ug-chrome.html
custom offset $25 ea
custom paint $50 ea [powder coat white]
6 week delivery made to order in house
and numerous accounts of Ford 16x7 working just fine..
I actually have a couple of sets but can't even get them painted with all the rain here in 'sunny' ca
Killer Bee is online now   Reply With Quote
Old 03-25-2020, 01:22 PM   #19
EricU
Well, nothing wrong with an old Binks. For one set of rims, it's probably not worth buying a new gun unless you want to.
If you are in Northern California, you could bring them over to my house and I'll shoot them, I even have the epoxy as I buy it by the gallon. Of course you'll have to do the prep!!
Old 03-25-2020, 01:23 PM   #20
THI
THI's Avatar
Ford E350 rims are 16x7, some will hold the stock Chevy/GMC dog dish hubcaps and some only take the larger 16" hubcap. I put a set on a 1977 K20 I sold three years ago and have another set for my current 1978 GMC K25. both sets I have would not take the dog dish hubcaps, bet in both cases I am fine without any.
The stock GM rims were 16x6.5 for the 1980's square bodies.
THI is offline   Reply With Quote
Old 03-25-2020, 06:10 PM   #21
SCOTI
SCOTI's Avatar
x2. This is valid info as of 2019.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 03-25-2020, 08:42 PM   #22
kidatheart
kidatheart's Avatar
I have 2 ol’ number 7’s hanging on the hook. That is all I ever used after learning to paint with one 40 years ago....guess we are in the same club
kidatheart is offline   Reply With Quote
Old 03-25-2020, 11:40 PM   #23
3x2GTO
I had a bout with cancer 30 years ago, doctor recommended staying away from body work. I took his advice and had no issues since, next scan is in April. I better forget the dog dish idea and buy chrome.
Old 03-26-2020, 10:33 AM   #24
SCOTI
SCOTI's Avatar
Just use a rattle can. As stated, scuff the PC, wipe it down w/degreaser & spray the color of choice. Done.
I've used rattle cans to color coat for my steelies over the 30+ years I've been tweaking my rides. Never had an issue that couldn't be easily addressed. Over bare steel, over PC, over old OE paint.
Rattle can paint can chip/scratch.
Paint gun paint can chip/scratch.
Chrome can rust/scratch.
PC can chip/scratch.
Which is easiest to spot repair in a moments notice?
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 04-01-2020, 02:03 AM   #25
ShortHaul
ShortHaul's Avatar
As Killer Bee mentioned WV will custom paint most basic colors. But they don’t offer free shipping like Jegs or Summit does. Plus add the extended lead time.
I had em blasted and powder coated white by Les Schwab for $40 a wheel.
"Sweet Pea" 1975 Cheyenne 20
http://67-72chevytrucks.com/vboard/s...00#post8477900
"Bourbon" 1975 Suburban ScottsdaleSOLD
https://67-72chevytrucks.com/vboard/...49#post8769049
”Otis” 1970 C10 SWB -SOLD
http://67-72chevytrucks.com/vboard/s...d.php?t=762766
”Chebby” 1962 Impala LS/TKO-500
http://www.pro-touring.com/threads/1...2-Impala-Build
ShortHaul is offline   Reply With Quote
