Old 09-12-2020, 09:21 PM   #1
Clatterville trolley
Clatterville trolley's Avatar
Differences in bell-cranks between trucks with 6 cyl and 8 cyl engines??
I have a person wanting to purchase a frame to engine bell-crank for a 427 v-8 with 4 speed transmission he is installing in a 67-68 C10. Anyone know what this part should look like?? I have a couple or three, but not sure what they fit.
Any help / pictures would be appreciated! Jay
PayPal 1windyridgeboy@gmail.com
Last edited by Clatterville trolley; 09-12-2020 at 09:22 PM. Reason: Left out some of explanation.
Clatterville trolley is offline   Reply With Quote
Old 09-12-2020, 10:14 PM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: Differences in bell-cranks between trucks with 6 cyl and 8 cyl engines??
I'm going to follow along on this one. I have a lot of different styles but I don't know what they fit either..... Post up some pictures if you can.
Bump for you.
LockDoc
Leon
Old 09-12-2020, 10:39 PM   #3
gmc684x4
I am going to say same one as a small block bell crank
The strait 6 ones are different i dont rember fully in what way been a long time since i had a 6 banger
https://www.brotherstrucks.com/67-72...tinfo/BLC6772/
gmc684x4 is offline   Reply With Quote
Old 09-12-2020, 10:52 PM   #4
gmc684x4
Here is a couple of pics from the V8 one from my 72
You can measure the distance from the frame rail mount to the engine block as a double check
that you can drop a big block and a small block on the same frame perches tells be it will fit
All 67 72 K series trucks use the back mount position it is only in the C models that they move the engine front or back depending on 6 or 8 cylinder
When I start putting my C10 together I will keep the motor back make room for the long water pump and serpentine belt setup
When I talked to My Late cousin before he passed last month about his 69 with a 396 he kept the motor in the back position as well for better header room
Old 09-12-2020, 11:01 PM   #5
Ironhorse
Ironhorse's Avatar
No authority by any means but I thought the BBC bell cranks or Z-bars were different than the SBC which is different from the IL6.
1971 Chevy 1/2T 4x4 LWB 350 V-8
Was sm465-now 350TH/np205
Tilt, Tach, Towhooks
Original Truck AM/FM
Wellington, Ks
Ironhorse is offline   Reply With Quote
Old 09-12-2020, 11:01 PM   #6
Thanks for the input and photos with measurements!! If I remember correctly the pivot that bolts to the engine that this crank swings on for 6 cylinder is much taller? / longer than the one that a small block uses. But just can't remember on crank differences.
Also thought maybe because he was using a 427 that the crank would be entirely different or not?
Last edited by Clatterville trolley; 09-12-2020 at 11:02 PM. Reason: left out words
Old 09-12-2020, 11:09 PM   #7
geezer#99
geezer#99's Avatar
You should be able to find one here.
At least an idea what you need.
They might even have an answer for you.
https://www.4speedconversions.com/se...?keyword=Z+bar
Old 09-12-2020, 11:29 PM   #8
Thanks for the link - scanned over it quickly and looks like lots of info, will read more in depth tomorrow! Jay
Old 09-12-2020, 11:54 PM   #9
LockDoc
LockDoc's Avatar
I can measure the one in my Green '67 in the morning, it has a 250 I6, and the '72 Dually, it has a 350 with the SM465 linkage in it. I will take pictures of the other ones I have for reference also.
LockDoc
Leon
Old 09-13-2020, 02:40 AM   #10
'68OrangeSunshine
'68OrangeSunshine's Avatar
L6 Z-Bars have to be longer. The L6 block is skinnier than the V8.
'68OrangeSunshine is online now   Reply With Quote
Old 09-13-2020, 03:49 PM   #11
Isn't the pivot point that bolts to the block longer too on L6 to help make up the distance? Jay
Old 09-13-2020, 04:01 PM   #12
'68OrangeSunshine
Yes. On my V8 truck, a '71 GMC Jimmy 4x4, w/350 SBC, the ball-stud engine-side pivot threads directly into the side of the block.
On my L6 truck --'68 C/10 Stepside, w/292, there's a ''U'' bracket that extends 4'' and then the ball stud pivot extends from there.
Old 09-13-2020, 03:57 PM   #13
geezer#99
geezer#99's Avatar
Six banger had a bracket similar to this to make up the distance.
Truck one was slightly different.
https://www.ebay.com/i/153926914679?chn=ps
V8 had a pivot ball that screwed into a threaded hole in the block.
Old 09-13-2020, 04:51 PM   #14
Bracket shown in the above ebay ad is what I was thinking about for L6 exactly.
Old 09-13-2020, 05:01 PM   #15
Grumpy old man
Grumpy old man's Avatar
Here are a few 6/small block the 4th one down is for a small block IIRC and alignment of pivot plate on small block.
Old 09-13-2020, 05:03 PM   #16
Thanks for input and photos Grumpy!
Old 09-13-2020, 07:24 PM   #17
'68OrangeSunshine
Looks very familiar.
Old 09-16-2020, 07:49 PM   #18
Thanks for everyone's input and ideas!! Jay
