12-04-2020, 03:13 PM | #1 |
Bed pads?
Working on a steel bed floor, bought the common available bed pads when I got into this thing, but then realized that messes up the body lines. I think those pads are 1/4", I don't care
I think some padding will improve the ride a pinch. The bed leaves a mark on the frame inviting rust too, not that rust is a problem here, but why mark up a refreshed frame if you don't have to. I'm edging toward this 1/32" neoprene. No adhesive, maybe you know of an adhesive just strong enough to put the bed on? Grease is out I suppose I could get away with 1/16", there is a stretch factor. SWB bed probably weighs 400ish, but declared Tensile Strength on this 1/32" is 1000 PSI. What have you used with success? https://www.amazon.com/Rubber-Buna-N.../dp/B01LZI39LG
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
12-04-2020, 04:47 PM | #2 |
Carpe manana
Re: Bed pads?
I used those little asphalt pads. Do my body lines look much off? Seem close enough.
12-04-2020, 05:10 PM | #3 |
Re: Bed pads?
I don't know more than that's a beautiful truck
12-05-2020, 09:55 AM | #4 |
Carpe manana
Re: Bed pads?
Thanks Tony!
