06-15-2021, 08:15 PM | #1 |
Rear disc help!!
hows it going guys!... I purchased a set of GM12 Bolt Rear End Disc Brake Caliper Brackets. These fit GM Metric brake calipers with 5.45" center-to-center bolt spacing, and can also be used with GM Metric calipers with E-Brake (like 1980-85 Cadillac Seville).....what id like to know is what rear disc can I use where I dont have to machine the drum register like you do with the captainfab bracket.
06-15-2021, 09:21 PM | #2 |
Re: Rear disc help!!
Most brackets I have seen fit d52 calipers which are 76 ish Eldorado cars for a working ebrake
06-16-2021, 04:22 PM | #3 |
I purchased bolt on rear caliper brackets from McGhaughy's before I ever heard of Capt Fabs set up and was able to use a D154 front caliper from a 1996 S10 along with 1996 Impala SS rotors. The original plan was to use a set of Cadillac Seville calipers that I had but I decided against them. What rear axles do you have?
06-23-2021, 03:51 PM | #4 |
I am keeping the 6x5.5 bolt pattern.
06-27-2021, 11:45 AM | #5 | |
06-27-2021, 08:36 PM | #6 |
60-66 Nut
As far as I know there are no 6 x 5.5 disc rotors that have a center hole of ~3.50" If there was, I would have used them in both of my 6 x 5.5 rear disc conversion bracket assemblies. Machining the hub register on the stock '63-'70 6 x 5.5 axles is just something that has to be done of you are wanting to upgrade to disc brakes.
06-19-2021, 10:16 PM | #7 |
What kind of setup can be used for a stock wheel 15 " 6 lug rim ?
dont want to hear excuses, i want to hear solution(s) |
