12-12-2021, 03:44 AM | #1 |
Roof Skin with Marker Lights
HI I have gmc truck 1970 without Marker Lights And I have Roof with Marker Lights from another truck. Is there an ideal and fast way to make the holes. I hope there are pictures of this work. Thanks
MY Facebook ( saad_alhajri ) on Instagram
12-12-2021, 12:37 PM | #2 |
Re: Roof Skin with Marker Lights
The roof marker lights are mounted on a raised flange (or boss?) so you might be better off swapping out the whole roof panel in order to duplicate that flange
71 Chevy C10 Shortbed Stepside. LT1 with 4l60E. Just got back from painter, in assembly now. |
12-12-2021, 12:40 PM | #3 |
I am going through this process right now. I hate to say it but the words quick and maker lights don't go in the same sentence lol. But it is possible and the end result is very worth it, there are several photos in the link on my signature. Let me know if you have any further questions!
1987 V30 Silverado SRW 454/400 4x4 104k original paint 1979 GMC C3500 Sierra Classic 3+3 454/4l80e 1971 K20 Cheyenne: http://67-72chevytrucks.com/vboard/s...d.php?t=804580 https://67-72chevytrucks.com/vboard/...d.php?t=837441 Instagram: jt_trucks3500 |
12-12-2021, 01:15 PM | #4 | |
Your work is great sir, but it is suitable for a whole new project. I want to keep my truck as much as possible in its original shape. I hope you understand this
12-12-2021, 05:35 PM | #5 | |
12-12-2021, 01:08 PM | #6 |
Thank you for your response, but I prefer to make holes and then solder the place. The holes are in the middle I'm thinking to cut them all and then solder
12-12-2021, 06:03 PM | #7 |
I understand completely with trying to keep the truck original. I am interested to see if the pedastals can be retrofitted onto a non cab light roof. It sounds like quite an undertaking with quite a bit of body work needed around the bases. Excited to see if anyone has approached the cab light dilemma in such a way.
12-12-2021, 06:38 PM | #8 |
I also cut my roof skin off and replaced it.
72 3/4t Custom Deluxe 402/auto 66k Original paint 71 3/4t 4x4 Custom Deluxe 10k original miles Original paint 71 3/4t Cheyenne 402 70k original paint 72 3/4t 4x4 Custom deluxe 72 3/4t 4x4 Custom deluxe 91k original paint 72 Cheyenne/30 Dually 69 Camaro SS396 4-speed 13 GMC 2500HD Duramax I bought new 05 Jeep Wrangler "Willys Edition" 12k miles (I bought new) 85 3/4 ton 4x4 Scottsdale 33k miles original paint 86 1 ton 4x4 SRW Silverado 454 restored 80 1 ton 4x4 SRW Silverado 9,434 original miles!! original paint 95 GMC 1 ton dually 4x4 my dad bought new 95 GMC 3/4 ton 4x4, regular cab 454, 31k original miles 2002 2500HD 4x4 regular cab 6.0L 67k miles 2002 2500HD 4x4 regular cab 8.1L 28k miles 2003 GMC 2500HD 4x4 regular cab Diesel 93k miles 67-72 Parts for sale |
12-12-2021, 08:32 PM | #9 |
6>8 Plugless........
You can cut the marker lamp bases off and transfer them to the cabs roof skin. It just takes measuring. It would be faster than installing a complete roof skin I'd think.
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
12-12-2021, 10:56 PM | #10 |
Removing the complete roof skin was super easy. We drilled out the spot welds on the roof, and around the rear window opening. The only cut we made was the rear cab pillar skin. Spot welded it all back together, and the only body work was on the rear of the cab. Seam sealed the roof again just like factory. It was done in 2 days.
12-12-2021, 11:27 PM | #11 |
All about them K’s
That’s good info Joe. I like that you didn’t mess with the rear upper seam above the back glass. Looks like a pretty clean way to go about it. I wonder how modern panel bonding adhesive would have worked in this application, obviously the back seams would need welded but other wise glueing it up might be a great way to do it.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne: 5” lift, 35’s, front dana 60 blah blah blah… http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB: 4” lift 33”s… in a million pieces http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 35x12.5x20’s |
01-06-2022, 02:56 AM | #12 |
Looks like I need a bigger plate. There is no other solution. If anyone has a bigger one than this I will be thankful. Thank you everyone
01-06-2022, 10:14 AM | #13 |
There are no shortcuts to this modification. Joe's Junk did his about the swiftest I see it. I also realize the scary prospect of cutting off the whole skin on such a nice truck as yours. That being said, " if you want an omelet, you've got to break a few eggs". I guess another alternative would be to cut the sections out like I have marked your picture and drop your headliner and trace the cut sections out on your roof and cut it. Weld them in very slowly and cross your fingers that you don't have a tremendous amount of warpage. Paint the roof and hope for good results. Whatever you decide, good luck.
:My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=807535 1972 K10 swb/1968 Camaro 350/4spd 1955 210 2 dr sedan/1998 RCSB Z71 |
01-06-2022, 12:22 PM | #14 | |
I appreciate it Bro , thanks
01-06-2022, 10:37 AM | #15 |
Carpe manana
Just buy another 70 GMC with roof marker lamps - problem solved
01-06-2022, 12:26 PM | #16 | |
In my country these lights in a truck are worth a fortune. Actually the selling price is different. In any case, the solutions are many, but the chance of finding a ready-made truck is very difficult . When I bought this truck, I couldn't believe it was still in factory condition. So I don't want to change this beauty except for the better
01-06-2022, 04:07 PM | #17 |
I have a whole cab with the lights rust free ,body guy can cut it off we’re you want it cut let me know have someone who wants the ac dash so might be willing to cut it up thanks Kenny
01-30-2022, 08:24 AM | #18 |
Work has started now and I will post pictures soon ..
01-30-2022, 10:00 AM | #19 |
Are you going to cut the entire roof off? or just the outer skin?
01-30-2022, 10:31 AM | #20 |
All you need to remove is the outer skin. Don’t cut the whole roof off your truck.
01-30-2022, 10:42 AM | #21 |
Yes, this is what I will do. top part only
01-30-2022, 10:50 AM | #22 |
You will be very happy with it. Cab lights are one of the coolest options. Good luck on your truck.
01-30-2022, 11:27 AM | #23 |
I think it would be really beautiful. I hope we do the perfect job. I will be uploading pictures soon
01-31-2022, 10:20 AM | #24 |
Proprietor of Dale's Corner
Looking forward to seeing the pics!
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man R.I.P. FleetsidePaul |
02-07-2022, 09:45 AM | #25 |
This is some pictures
