Old 12-12-2021, 03:44 AM   #1
a Good Man
a Good Man's Avatar
Roof Skin with Marker Lights
HI
I have gmc truck 1970 without Marker Lights And I have Roof with Marker Lights from another truck. Is there an ideal and fast way to make the holes. I hope there are pictures of this work. Thanks
MY Facebook
( saad_alhajri ) on Instagram
a Good Man is offline   Reply With Quote
Old 12-12-2021, 12:37 PM   #2
FL71C10
Re: Roof Skin with Marker Lights
Originally Posted by a Good Man View Post
HI
The roof marker lights are mounted on a raised flange (or boss?) so you might be better off swapping out the whole roof panel in order to duplicate that flange
71 Chevy C10 Shortbed Stepside. LT1 with
4l60E. Just got back from painter, in assembly now.
FL71C10 is offline   Reply With Quote
Old 12-12-2021, 12:40 PM   #3
JT_Trucks87
JT_Trucks87's Avatar
I am going through this process right now. I hate to say it but the words quick and maker lights don't go in the same sentence lol. But it is possible and the end result is very worth it, there are several photos in the link on my signature. Let me know if you have any further questions!
1987 V30 Silverado SRW 454/400 4x4 104k
1979 GMC C3500 Sierra Classic 3+3 454/4l80e
1971 K20 Cheyenne
http://67-72chevytrucks.com/vboard/s...d.php?t=804580
https://67-72chevytrucks.com/vboard/...d.php?t=837441
https://67-72chevytrucks.com/vboard/...92#post9355392
JT_Trucks87 is offline   Reply With Quote
Old 12-12-2021, 01:08 PM   #4
a Good Man
a Good Man's Avatar
Thank you for your response, but I prefer to make holes and then solder the place. The holes are in the middle I'm thinking to cut them all and then solder
MY Facebook
Old 12-12-2021, 01:15 PM   #5
a Good Man
a Good Man's Avatar
Your work is great sir, but it is suitable for a whole new project. I want to keep my truck as much as possible in its original shape. I hope you understand this
MY Facebook
Old 12-12-2021, 05:35 PM   #6
davischevy
davischevy's Avatar
I'm glad you answered. I saved me the trouble of looking up your info.
other Larry
Build thread, Arkansas K10
https://67-72chevytrucks.com/vboard/...=755797&page=5
The ability to speak several languages is an asset, but the ability to keep your mouth shut in any language is priceless.
davischevy is offline   Reply With Quote
Old 12-12-2021, 06:03 PM   #7
JT_Trucks87
I understand completely with trying to keep the truck original. I am interested to see if the pedastals can be retrofitted onto a non cab light roof. It sounds like quite an undertaking with quite a bit of body work needed around the bases. Excited to see if anyone has approached the cab light dilemma in such a way.
1971 K20 Cheyenne
Old 12-12-2021, 06:38 PM   #8
Joesjunk
Joesjunk's Avatar
I also cut my roof skin off and replaced it.
72 3/4t Custom Deluxe 402/auto 66k Original paint
71 3/4t 4x4 Custom Deluxe 10k original miles Original paint
71 3/4t Cheyenne 402 70k original paint
72 3/4t 4x4 Custom deluxe
72 3/4t 4x4 Custom deluxe 91k original paint
72 Cheyenne/30 Dually
69 Camaro SS396 4-speed
13 GMC 2500HD Duramax I bought new
05 Jeep Wrangler "Willys Edition" 12k miles (I bought new)
85 3/4 ton 4x4 Scottsdale 33k miles original paint
86 1 ton 4x4 SRW Silverado 454 restored
80 1 ton 4x4 SRW Silverado 9,434 original miles!! original paint
95 GMC 1 ton dually 4x4 my dad bought new
95 GMC 3/4 ton 4x4, regular cab 454, 31k original miles
2002 2500HD 4x4 regular cab 6.0L 67k miles
2002 2500HD 4x4 regular cab 8.1L 28k miles
2003 GMC 2500HD 4x4 regular cab Diesel 93k miles
67-72 Parts for sale
Joesjunk is offline   Reply With Quote
Old 12-12-2021, 08:32 PM   #9
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
You can cut the marker lamp bases off and transfer them to the cabs roof skin. It just takes measuring. It would be faster than installing a complete roof skin I'd think.
Ryan
1969 Chevy milk truck
Old 12-12-2021, 10:56 PM   #10
Joesjunk
Joesjunk's Avatar
Removing the complete roof skin was super easy. We drilled out the spot welds on the roof, and around the rear window opening. The only cut we made was the rear cab pillar skin. Spot welded it all back together, and the only body work was on the rear of the cab. Seam sealed the roof again just like factory. It was done in 2 days.
Old 12-12-2021, 11:27 PM   #11
57taskforce
All about them K’s
57taskforce's Avatar
That’s good info Joe. I like that you didn’t mess with the rear upper seam above the back glass. Looks like a pretty clean way to go about it. I wonder how modern panel bonding adhesive would have worked in this application, obviously the back seams would need welded but other wise glueing it up might be a great way to do it.
Tyler
57taskforce is online now   Reply With Quote
Old 01-06-2022, 02:56 AM   #12
a Good Man
a Good Man's Avatar
Looks like I need a bigger plate. There is no other solution. If anyone has a bigger one than this I will be thankful. Thank you everyone
MY Facebook
Old 01-06-2022, 10:14 AM   #13
tutone
tutone's Avatar
There are no shortcuts to this modification. Joe's Junk did his about the swiftest I see it. I also realize the scary prospect of cutting off the whole skin on such a nice truck as yours. That being said, " if you want an omelet, you've got to break a few eggs". I guess another alternative would be to cut the sections out like I have marked your picture and drop your headliner and trace the cut sections out on your roof and cut it. Weld them in very slowly and cross your fingers that you don't have a tremendous amount of warpage. Paint the roof and hope for good results. Whatever you decide, good luck.
:My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=807535
1969 C10 swb/1968 Camaro 350/4spd
1955 210 2 dr sedan/1998 RCSB Z71/1977 Jeep CJ5
tutone is offline   Reply With Quote
Old 01-06-2022, 10:37 AM   #14
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Just buy another 70 GMC with roof marker lamps - problem solved
Old 01-06-2022, 12:22 PM   #15
a Good Man
a Good Man's Avatar
I appreciate it Bro , thanks
MY Facebook
Old 01-06-2022, 12:26 PM   #16
a Good Man
a Good Man's Avatar
Hahahahahh
In my country these lights in a truck are worth a fortune. Actually the selling price is different. In any case, the solutions are many, but the chance of finding a ready-made truck is very difficult . When I bought this truck, I couldn't believe it was still in factory condition. So I don't want to change this beauty except for the better
MY Facebook
Old 01-06-2022, 04:07 PM   #17
best view
I have a whole cab with the lights rust free ,body guy can cut it off we’re you want it cut let me know have someone who wants the ac dash so might be willing to cut it up thanks Kenny
best view is offline   Reply With Quote
Old 01-30-2022, 08:24 AM   #18
a Good Man
a Good Man's Avatar
Work has started now and I will post pictures soon ..
MY Facebook
Old 01-30-2022, 10:00 AM   #19
JT_Trucks87
Are you going to cut the entire roof off? or just the outer skin?
1971 K20 Cheyenne
Old 01-30-2022, 10:31 AM   #20
Joesjunk
Joesjunk's Avatar
All you need to remove is the outer skin. Don’t cut the whole roof off your truck.
Old 01-30-2022, 10:42 AM   #21
a Good Man
a Good Man's Avatar
Yes, this is what I will do. top part only
MY Facebook
Old 01-30-2022, 10:50 AM   #22
Joesjunk
Joesjunk's Avatar
You will be very happy with it. Cab lights are one of the coolest options. Good luck on your truck.
Old 01-30-2022, 11:27 AM   #23
a Good Man
a Good Man's Avatar
I think it would be really beautiful. I hope we do the perfect job. I will be uploading pictures soon
MY Facebook
Old 01-31-2022, 10:20 AM   #24
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
Looking forward to seeing the pics!
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
R.I.P. FleetsidePaul
Old 02-07-2022, 09:45 AM   #25
a Good Man
a Good Man's Avatar
This is some pictures
MY Facebook
