Why is the light on constantly?
I noticed my battery going down if I did not drive it for a few days. One night I went out and the light that lights up the gear position was on. The P R N D L1 L2 is what I am talking about. ANyone have any ideas about this?
thanks Ron
Life is full of choices and a Chevy is the best choice. 1990 Chevy SWB |
Robert Olson Transport
![]() Join Date: Oct 2002
well that light isnt suppoused to be on unless you have your headlights/markers on. Im guessing you have a short in the column with one of the wires that is constantly hot ( ignition) id look there first
Bob 1951 International running on a squarebody chassis "If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board" http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!) PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport Live each day to the fullest.. you never know when fate is going to pull the rug out from under you... I hate cancer!! |
that light is really not a light at all.............
it's a fiber optic cable coming from the dash bezal..... try turning the dimmer to see if the light get's brighter? more than likely a bad head light switch............ MAY THE FORCE BE WITH YOU ![]() Last edited by rage'nrat638; 12-28-2003 at 12:06 PM. |
My guess is that the truck has tilt and the light is plugged into the wrong spot on the fuse panel. There is no way for the fiber optic cable to have light on it without the dash lights being on if it is hooked up the stock way.
Jim |
its all about the +6 inches
I'll take a guess and say you have a tilt column.
Look on the bottom of the collumn under the dash where the harness comes out. Find the gray wire that is seperate from all the others. Follow that to the fuse box, and unplug it from the constant hot circuit, and install it on the one that says lights (Or somethign to that effect) This will make it so that light will only come on with your headlight switch in either park light position, or in the headlight on position. If you don't have a tilt, then some one has been in there and done a conversion with a light bulb instead of the fiber-optic cable that it is supposed to have. Follow the same as above. If you DO have a fiber optic cable running from the collumn to the inst. panel, then you have some big wireing trouble that you need to sort out. (like dash lights staying on). |
