02-28-2022, 07:54 AM | #1 |
Brake Line
The steel Brake Line that runs from front to rear, burst about 3 feet in front of the rear axle last night. I would like to stop at a local auto part store on my way home tonight and pick up a premade brake line to replace it.
What is the length and type that I will need to pick up (assuming they make one off the shelf that will fit)? This pic shows the line that I need to replace. Thanks |
02-28-2022, 10:06 AM | #2 |
Re: Brake Line
Local auto parts stores aren't going to have a premade line in stock , The way I see it is you have 4 choices ,
1) stop at a local brake shop and have them install a section in your existing line They may not want to patch a brake line , 2) Call Inline tube and buy the section you need and have it shipped to you . 3) Contact Ecklers in Florida and buy a new kit and use the section from the kit you need and replace all the other lines when you have the time . 4) buy a short section and line connectors from an auto parts store and cut / flare and repair it yourself , But if one line "burst " the rest should be replaced . You didn't mention what year or model truck you have . https://www.ecklers.com/catalogsearc...q=brake%20line https://www.inlinetube.com/?category...SAAEgL46fD_BwE
1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
02-28-2022, 10:18 AM | #3 |
Re: Brake Line
1967 2wd 1/2 Ton Pick-up.
I found this one on Eklers, is this the correct one? https://www.ecklers.com/1967-72-chev...ails_tab-title |
02-28-2022, 10:33 AM | #4 |
Re: Brake Line
If you have a Short bed ?
That looks like the one , Don't forget to use line wrenches to avoid twisting off the old connections when removing the bad section . There's not a lot of room to work in at the rear connection , don't forget brake fluid and your going to have to bleed the system . Have fun ! I hate working on old brake lines .
1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop Last edited by Grumpy old man; 02-28-2022 at 10:48 AM. |
02-28-2022, 10:40 AM | #5 | |
Re: Brake Line
The link you provided does not work. |
02-28-2022, 10:47 AM | #6 |
Re: Brake Line
Use the link you provided , I just copied it from your post .
02-28-2022, 06:51 PM | #7 |
Re: Brake Line
If that steel line rusted thru, how old are the brake hoses? If I was going to replace my brake lines, I sure would replace the hoses. I do not like bleeding brakes and I would not like to go back and replace the brake hoses and have to bleed the brakes again. I just thought See if you can get the bleeder screws to turn on the wheel cylinders. They just might brake off and need replacing too.
03-01-2022, 07:23 AM | #8 | |
Re: Brake Line
03-01-2022, 09:30 AM | #9 |
Re: Brake Line
Some people overlook the obvious.
03-31-2022, 02:14 PM | #10 |
Re: Brake Line
Well, the line I ordered from inline tubing arrived yesterday. They had to make the line as it is not something they stock. The line was a perfect fit and needed no modifications to work. shipping was a little slow but worth the wait.
