Old 03-10-2022, 09:41 PM   #1
Dodge68charger
Wiring Question
Any Issues With This Setup?
There Is a Fusible Link at The Starter As Well
Dodge68charger is offline   Reply With Quote
Old 03-10-2022, 10:46 PM   #2
HO455
HO455's Avatar
Re: Wiring Question
We need much more information before anyone can make any decisions as to good or bad.
What sizes are the wires involved?
How long are they?
Is the battery in the stock location?
Where in the starter circuit is the fuseable link?
What size fuseable link?
Are you using a factory switch fuse block?
And I'm sure I've missed somethings.
Every detail will help. Photos will be beneficial too.
You are asking for information that if miscommunicated could result in your truck catching fire. Nobody here wants to see that or wants to feel responsible for contributing to something like that.
RIP Bob Parks.
Old 03-11-2022, 01:52 AM   #3
kwmech
Re: Wiring Question
^^^what he said, picture shown is bogus for a 67-72 chevy unless you are severely upgrading for a monster stereo system or a whole lota lights and a winch
Old 03-11-2022, 02:46 PM   #4
Dodge68charger
Sorry Guys I ll Get Some Pictures Later Today. Everythings 8 Gauge Wiring From American Autowire.
The First Red 8 Gauge Wire Goes From My Starter Solenoid
Main + Post To The Alternator Aith An AAW Fusible Link That Came In There Kit Between The Two.
Running Power From The Starter Solenoid To The AAW Fuse Block in The Cab. With Routing Along The Rad Support Its Probably About 7 Feet Away
Just Was Wondering If I Should Put a Circuit Breaker In Between The Starter and Fuse Block?
Im Just Trying To Cover All My Bases In Case Of a Shortt or I Gotta Jump Start The Truck So I Dont Ruin The Fuse Box
Old 03-11-2022, 04:11 PM   #5
kwmech
Re: Wiring Question
Eliminate the wire to and from the starter post and go direct. having it down there will cause resistance when it gets hot from the exhaust or engine block. All you need at the post is the batt cable. 8g wire will not handle a 200a load. 145a alt should have at least a 6g wire to the batt. (maybe even a 4) Going into the cab fuse block 8g may be a little overkill as it will not fit into the bulk head connector correctly
Old 03-11-2022, 07:42 PM   #6
MikeB
MikeB's Avatar
Re: Wiring Question
What kind of vehicle? Stock fuse panel?
Mike
1969 C10 LWB -- owned for 35 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, recent AAW wiring harness, 5-lug conversion, 1985 spindles and brakes.
1982 C10 SWB -- sold
1981 C10 Silverado LWB -- sold, but wish I still had it!
1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming.
Retired as a factory automation products salesman.
Worked part-time over the years for an engine builder and a classic car repair shop.
Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then!
MikeB is offline   Reply With Quote
Old 03-11-2022, 09:12 PM   #7
Dodge68charger
1969 C10. American Auto Wire Panel
Old 03-12-2022, 11:22 AM   #8
Dodge68charger
I Know The Wire Wont Handle 200 amp but Thought Id Put That There In Case Of a Voltage Spike. Jump Starting
I Think I ll Just Go From The Starter post Direct To The Fuse Box
The Fusible Link Should Hold
Old 03-12-2022, 05:00 PM   #9
HO455
HO455's Avatar
Re: Wiring Question
Here is a link to the Mad Electrical site. (There are several pages on alternators alone) They have lots of good information on how to make alternator upgrades. It may help you finish your project.
Good luck.
http://www.madelectrical.com/electri...evymain1.shtml
RIP Bob Parks.
Old 03-13-2022, 01:49 PM   #10
MikeB
MikeB's Avatar
Re: Wiring Question
Look at Page 3 here to see how AAW does it.
https://www.americanautowire.com/med...20IN%200.1.pdf
Mike
