6 lug front rotors
im going to convert over to discs and i have 6 lug but the rotors i have are 5 lug. can i buy the 6 lug rotors from an auto parts store or does it have to be from a catalog/vendor?
70 longbed 496/th400/Ford 9" |
How about changing your rear axles so you have 5 lug all around? You can get cooler rims for 5 lug.
Where did you get the rotors you have? A donor front end? Early Classic, Classic Performance (probably lots of others offer 6 lug rotors). good luck, scott
Silence is golden, duct tape is silver. - Scott |
i thought about that... but i would have to change rims and i got some decent chrome rims on there. i like 6 lug more. ive seen some cool 6 lug wheels. i know wes sells the rotors but he is way to far away to be shipping that big item to me.
Project Junkie! Fishing Poor!!
![]() Join Date: Dec 1999
dinnut, There isn't any stock aplication 6 lug rotors that will bolt onto your 71-72 front spindles. These are a specialty itom only. You can take your 5 lug rotors have the holes filled and then redrilled for 6 lug pattern though. That would be my only suggestion though. WES www.ClassicHeartbeat.com
On-line catolog Classic Heartbeat Pickup Parts WEHEPP@comcast.net Call us Toll Free (888) 338-2502 Like Us on Facebook No appointment necessary. 72 BB Chevy Custom Deluxe / Custom Camper 67 I-6 (Soon to be 5.7 LS1) Panel 68 BB Chevy Short Bed 72 6.0 LQ9 Short Bed Chevy 4X4 Olympia's fastest growing truck parts supplier. Olympia's home for Wayward Chevys |
Pennyless Fool
It would be nice if someone made a replacement spindle so we could use off the shelf rotors (late Chev). Especially for those of us who change pads when they start to grind.
"Who owns this car with the peace sign, the mag wheels, and four on the floor?" 67 Short Step 283/TH400/4.11 |
Old Skool Club
![]() Join Date: Jun 2001
You can buy the spindles from Early Classic Enterprises, with either a stock height or a 2.5 inch drop. Then, you can use the stock GM 5-lug rotor or the ECE 6-lug rotor. It is new, not redrilled. Not that there is anything wrong with a redrilled rotor, IF it is done correctly. ECE stuff uses GM 1/2-ton truck brake components.....all factory stuff. Their spindles are custom manufactured, with a lifetime warranty and use OEM tie rod ends, ball joints, etc.
Not to knock WES, at all. He's a good guy just trying to give you some options. But, you seem to be set on having a 6-lug disc on your 71-72 body, so that's my suggestion on how you can have it your way....short of going to Burger King, that is. Before I knew about Wes, I had already bought and installed the ECE components on my '69. This is why I can tell you about what they have.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
#7 | |
senior member
69 GMC bagged |
tommy . master of madness
ask ed
from mother truckers . i want ta say rotors off a 90 1/2 light duty 3/4 ton have the same raceses.
ask ed for sure tom |
#9 | |
nah, i got a complete set of discs and stuf in my garage. from the spindle to the dust cap i got the whole deal in my garage and want to put it on my 70... which is 6 lug... i already have 5 lug discs on the other truck and wouldnt want to put 6 on there...
pic of what i got. but i want 6 lug discs! like pissonnos said, to be different and so i dont have change rims...
senior member
rock on dinnut stay with the sixers
69 GMC bagged |
Old Skool Club
I stayed with the 6-lug because I already had a set of wheels, too. I also know that to the un-initiated, a set of disc brakes on any given vehicle ain't no biggee. Therefore, it just makes me feel good knowing that if someone is knowledgeable enough to notice, yes, I do have disc brakes on my '69. No, they didn't come on it. It has been converted.
Try ECE for the rotors. If your spindles are from a '71-72, there should be absolutely no problem putting their rotors on and then you'd have 6-lug without redrilling yours, plus, you'd have new rotors that will last for many years. But, whatever floats your boat.
go bucks!
remember also that w/ the tahoe's and denali's,etc... and all them suv's that are out there, the after-market has seriously stepped up the availability of cool looking 6 lug rims. so 5 luggers don't have such a monoply on the cool rims anymore!!
'68 swb 1/2t 350/350th '86 lngbd 3/4 TON parts getter '49 gmc 1/2 t 5 window 350/350th '96 gmc sonoma sle ext-cab. hey it's a 4cyl. 5 spd and good on gas y'know? |
I have nothing against 6 lug rims - I have 6 lug rallyes. I was just offering an option. What did your discs come off of? Classic Performance has rotors to fit on stock spindles, but I think they are 5 on 4-3/4 bolt pattern. Check them out, they may have the magic spindle for you www.classicperform.com
scott
#15 |
www.mcgaughysclassic.com is where i got six lug rotors for my 1980 spindles.they were 80 dollars each.im not sure if the 1971 spindles are the same.
#16 |
they look like
this
#17 |
..the new chevy trucks also went back to 6 lugs so i'm sure the wheel co. will be making more and more of them....
Ken Lyons, Slippery rock pa 68 short step 327 t10 4 gear 72 2wd blazer project 70 lwb 305/700r driver 78 caprice project 02 cavalier D.D ( hate it!!) |
#18 |
backspace
Hard to find them with the correct 4-1/2" backspace. I wanted Torque Thrust IIs, but I was told they wouldn't work, so I powder coated my ralleys and bought new rings and caps.
Scott
#19 |
i bought my setups used from a guy in dallas while i was up there they are off of a 71-72. im trying to figure who is closest to me to ship the rotors here. looks like mothertruckers might be. is mothertruckers still on the board?
