![]() Join Date: Sep 2003
Tell me more about your knob
Over the years there have been many peculiarities pointed out on these trucks. Here's another one I'm wondering about:
For trucks equipped with the NL2 option (which I believe was only offered in '72 for that RPO), regarding the knob on the dash, 1) Was a NL2 deluxe knob offered? 2) If yes, then what trucks received a deluxe NL2 knob? I thought that only Cheyennes and Supers would receive a deluxe knob. Others have told me that all trucks received this knob in the "standard" version. I have recently found a few pictures that have confused me even more. Wondering if it could be another difference depending on the factory? What are your thoughts? The first pic has a deluxe knob but standard foot pedals...??? The last pic is advertised as a mostly original Cheyenne and it has a standard knob. Last edited by 402Bowtie; 10-13-2022 at 07:44 PM. |
Re: Tell me more about your knob
FWIW my 72 low option knobs. IDK if original but assume so
![]() Join Date: Aug 2013
I thought
Deluxe knobs we’re on custom deluxe Cheyenne And supers Standard knobs were only on base model As for foot pedals Cheyenne and super got the deluxe pedal with the chrome trim Because they were the only trucks with carpet Custom deluxe or lower got standard pedal Because they had rubber floor mats Additionally there was only a deluxe knob for all cigarette lighters Because the chrome center was a push button Those are only my thoughts and observations Not fact |
#4 | |
Yes, lower trim models had the standard knobs. I'm wondering specifically about the NL2 knob on the higher trim models.
The last pic still confuses me. I feel like I've seen a few other Cheyennes or Supers with the standard NL2 knob. |
#5 | |
![]() ![]() Join Date: Feb 2009
Learn something new everyday, that's real interesting about rubber floor mats gets plain foot pedals. Since I got carpet now, does that mean I need chrome trim?.............NEVER! Post 12 may have something to say about that theory, perhaps the brake pad trim was added later. Purdy knobs
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly guide (kit) for restoring this truck from the ground up, complete with details including full hardware descriptions. Much of the info. applies to all 67-72 GM. My build thread, with some info. about the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 03-01-2024 at 06:24 PM. |
![]() Join Date: Feb 2002
You can't get the all plastic, black Standard Knob thru the aftermarket vendors.
All they sell is the Deluxe with the metal center. The Orange truck, 3rd pic in Post #1, has MY '72 Door Panels. My own '71 GMC Jimmy has the same DeLuxe knobs you'd find on a Chevy. I have a '67 K/10 Sub. It has black Standard knobs, but they're slightly different from the '68's. PIX: TOP -- '67 MID -- '68 BOTTOM -- '71
Every 25 years I like to rebuild that 292, whether it needs it or not. Last edited by '68OrangeSunshine; 10-13-2022 at 10:12 PM. |
All about them K’s
![]() Join Date: Jun 2014
My 72 K20 Cheyenne had the deluxe knob for the NL2 gauge switch (NL2 is on the spid) and I’m sure it was original as it was just as beat to hell as the rest of the knobs. I replaced it with a nicer condition deluxe knob I got from Pete. I don’t think I’ve ever seen a standard NL2 knob with out the bright insert until the picture posted above, I’ve probably just never paid much attention. This is a very interesting thread.
Unfortunately I don’t have any pics of the original knob, but can get one of the new one if needed. They are identical other than condition.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne: 5” lift, 35’s, front dana 60 blah blah blah… http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB: 4” lift 33”s… in a million pieces http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 35x12.5x20’s |
So the NL2 RPO option was the Fuel Tank Select switch to the left of the Dash Panel?
None of my trucks had that option.
All about them K’s
NL2 is the auxiliary tank option that included the auxiliary tank, sending unit, fuel selector valve, sending unit selector switch wiring, and auxiliary filler neck.
Was the NL2 knob the same size as the other knobs? In the first pic, it looks smaller, but that could be an optical effect of a very wide angle lens.
In the 3rd pic, of the Orange '72 cab, it looks like an all black Standard knob was used, while the rest of the trim is DeLuxe or Custom/Cheyenne. Likely the service dept used what they had a lot of. Or didn't care. Or it's a trick of the [low] light. Possibly the same part as the Wiper knob. Set screw from the side to secure on a D-sectioned shaft.
I appreciate the responses. I think I got all my questions answered and I think chevyland's response nailed it.
I saw this truck online today. Appears to be mostly original custom deluxe truck with NL2 option. |
Yes, Chevy Custom Deluxe, Cheyenne, and Cheyenne Supers with RPO NL2 got the matching deluxe knob and only Custom got the all black knob. The same is true for corresponding GMC trims
I still think some trucks (strangely) received a standard knob for the NL2 switch even if the other knobs on the dash were deluxe.
I recently was going through some of the parts off my K20 Cheyenne and found its original NL2 knob, which is a non-deluxe (standard) knob. I also saw the attached pics online today...Appears to be a fairly original interior (no SPID pics posted) for a Custom Deluxe equivalent GMC. Its NL2 knob is the only non-deluxe knob on the dashboard. |
Was the NL2 Knob its own special part, or was it the same part as the Wiper Knob, which attached with a set screw on the side?
#15 |
![]() ![]() Join Date: Jul 2003
I will have to pull the NL2 knob from my 1972 Cheyenne and see if it is the same dimension as the wiper knob. It might be the same as the manual throttle control knob 1991067/1991072, which was a deeper knob also retained with a set screw. The manual choke or Suburban rear air knob 1991077 does not have a set screw for attachment.
Manual throttle knob: It appears that the knob is or is similar to the throttle knob based upon this pic Here is another photo of a true NL2 knob:
1970 K/5 Blazer CST 4WD, TOTM winner December 2024! Medium Bronze poly, 93k ACT. miles, 350, 4 speed, rear positraction, 16.5" x 8.25" HD Kelsey Hayes wheel option, tilt, tach, vacuum, AM/FM, manual throttle...Dad ordered and purchased new 4/70. Currently frame off restoration finally getting close to completion.. ![]() 1970 K20, To be a clone of my Grandfather's K20, Dark Blue poly, 350, 4 speed, 16.5" X 8.25" Kelsey Hayes wheel option, tilt, tach, vacuum, AM radio. Latest project truck 1972 Cheyenne Super 20 2WD, Dark Blue/White, 90K ACT. miles, 402, TH400, 4.10 open, tilt, tach, vacuum, A/C, AM/FM, manual throttle.. A mostly original paint never rusted Texas survivor... ![]() 2017 Sierra 1500 SLT 4WD, Black, 46k miles, 5.3, 6L80E, 3.42 LS, 20" polished wheels, everything but moonroof and 6.2... 2019 Canyon SLT 4WD, White, 67k miles, 3.6, 8L45, 3.23 LS, 18" wheels Last edited by 1970cstblazer; 03-02-2024 at 08:54 AM. |
