Old 01-03-2023, 10:52 PM   #1
Claimchaser
Jegs rally wheels question
Has anyone used the six lug 15x8 6x5.5 rally wheels offered by Jegs? Their page says the don’t fit but the specs seems to say they will?
Claimchaser is offline   Reply With Quote
Old 01-04-2023, 07:41 AM   #2
Claimchaser
Re: Jegs rally wheels question
Here is a photo of what I am thinking about purchasing. Their site says they won’t fit but I don’t see why they wouldn’t.
Old 01-04-2023, 11:26 AM   #3
jayoldschool
Moderator
Centre bore size check?
jayoldschool is offline   Reply With Quote
Old 01-04-2023, 02:24 PM   #4
Claimchaser
Here are the specifications given. Site says they will not fit?
Old 01-05-2023, 09:49 AM   #5
Claimchaser
Is a 4” backspace too much?
Old 01-05-2023, 12:38 PM   #6
theastronaut
theastronaut's Avatar
4" on an 8" rim is ideal.
theastronaut is offline   Reply With Quote
Old 01-05-2023, 09:02 PM   #7
VictoriaHardware
VictoriaHardware's Avatar
Center bore on factory wheel is 3 1/2". Jeg's wheel looks a LOT larger.
Here is a factory 15x8 6x5.5" wheel. 3 7/8" back spacing, 5/8" Offset. Used on 73-85 Chevrolet Military Blazer 4x4.
VictoriaHardware is offline   Reply With Quote
Old 01-05-2023, 09:52 PM   #8
Claimchaser
I have two 3 nub 15x8’s but haven’t found another pair so I am searching for an alternative
Old 01-05-2023, 10:14 PM   #9
Arne
Arne's Avatar
Try these. My truck has 5 lug discs, and I bought the Wheels Vintiques 15x8. The 6 lug should be fine.
https://www.summitracing.com/parts/wvi-62-5806044
- Arne
Finished Project - 1964 C10 Stepside, mild restomod
Arne is offline   Reply With Quote
Old 01-06-2023, 09:56 AM   #10
rbruno68
Attachment 2246251
Arne, Did they bolt up tight to the hub or are then centered on the studs? I think that is one of the issues with the Jegs rally. Well, not sure if it is an issue, but a difference.
Rob
rbruno68 is offline   Reply With Quote
Old 01-06-2023, 12:49 PM   #11
Arne
Arne's Avatar
My 5 lug wheels are centered by the lug nuts, not the hub. They work fine that way. Lug-centered wheels have been normal in the aftermarket pretty much forever. Most 6 lug aftermarket wheels will have the larger center bore so that they will fit more applications, like Toyota Land Cruisers.
But I'm thinking back to my first career selling wheels and tires from the mid-70s into the late 90s, and I recall an issue on the old GM trucks. I remember that many old drum brake GM trucks (and cars too) had big rivets between the lugs that attached the drums to the hubs. I don't see any rivet head clearance stamped into the Jegs Rallys. The nubbed wheels you have now look OK, and the Wheel Vintiques from Summit also look like they have the stamped relief.
So I'm guessing that the Jegs Rallys won't bolt up flush unless the rivet heads have been removed or clearanced. In the old days, lots of people just chiseled the heads off. Or you could grind them way down almost flush. But I'm betting that's why Jegs says they don't fit.
- Arne
Old 01-08-2023, 07:56 PM   #12
Claimchaser
They did have rivets on the front drums, but nobody ever put them back when the first brake job was done.
Old 01-10-2023, 12:39 PM   #13
rideblue00
rideblue00's Avatar
Claimchaser thats what I have on my truck
rideblue00 is offline   Reply With Quote
Old 01-10-2023, 09:40 PM   #14
Steveoreno
They fit on my 66 just fine!
Steveoreno is offline   Reply With Quote
Old 01-16-2023, 07:34 PM   #15
Claimchaser
Thank’s for all the replies! I decided on these, 18x8.5. Main reason is I was able to find a set with tires and they had less than 100 miles on them.
Old 01-17-2023, 05:39 PM   #16
bhap
bhap's Avatar
WheelVintiques has a "Style 62" wheel that is supposed to fit (as far as I can tell they do, but I have not purchased) and has the nubs to accept a center cap..
bhap is offline   Reply With Quote
