Old 02-09-2023, 10:58 PM   #1
jumpsoffrock
NV4500 shifter knub slop
Video: https://live.staticflickr.com/video/...NWUiLCJ2IjoxfQ
I feel like I'm jumping into this swap a bit too fast, but I also feel like I need to start somewhere. There's a guy within a couple hours of me selling NV4500's. They are all used, and I don't think they have a warranty, and the two I saw in person looked rough.
I made a vary quick video but I don't know if it even shows enough detail to show anything "wrong".
The slop in the shifter knob seemed a lot, but then again these trans were not known for their "modern precise feel"; from what I read they are marginally more modern feeling than an SM465.
He said he had a few other trans available at another location that we could go check out.
Is there anything I should be testing or looking at on an NV4500?
jumpsoffrock is offline   Reply With Quote
Old 02-11-2023, 01:43 PM   #2
HO455
HO455's Avatar
Re: NV4500 shifter knub slop
I know little to nothing about NV4500's but I do know these folks have been helpful to me in the past about other transmissions. You might try contacting them.
https://www.novak-adapt.com/knowledg.../manual/nv4500
RIP Bob Parks.
Old 02-11-2023, 09:30 PM   #3
hugger6933
The shifter tops are in rubber like deal and also the tops are a plastic composite[ from the best of my recollection so if I'm wrong dont fry me] It has been years since I did a nv4500 truck but I did build a ton of them back in the day. I wished I still had one but I sold almost all of my parts from that body style now they are really going up. Jim
hugger6933 is offline   Reply With Quote
Old 02-11-2023, 09:31 PM   #4
hugger6933
What I meant to say was until I distracted myself, is look at the tops good I had several that were in front crashes that would mess the top up and you had to watch for it on those. Jim
Old 02-11-2023, 11:53 PM   #5
LockDoc
The Older Generation
LockDoc's Avatar
If it is just the knob itself it may be the wrong knob and the threads don't match the shift lever. If the lever is loose in the tower it could be a couple of different things. There are two nylon pivot bearings that fit over the pins on the sides of the shifter stub, down inside the tower. They may be worn or missing. That would make the lever feel pretty sloppy. I guess it could also be other worn internal parts. It's really hard to say without being there to see what the symptoms are first hand.....
Here is the thread on my installation:
http://67-72chevytrucks.com/vboard/s...d.php?t=673588
LockDoc
Leon
Old 02-12-2023, 11:44 AM   #6
jumpsoffrock
Thanks you all for replies, I'll call Novak monday.
LockDoc
Leon, the lever is loose in the tower.
Apparently the video link I posted expired. Here it is again.
https://www.flickr.com/photos/127991...posted-public/
Old 02-12-2023, 04:24 PM   #7
jumpsoffrock
Here's my last darn try lol
https://www.youtube.com/shorts/uQ9BItTVfg0
Old 02-12-2023, 11:10 PM   #8
LockDoc
LockDoc's Avatar
That one worked. I bet the nylon pivot bushings are bad in it. If that is the problem they would be easy to change/replace. I explain how to remove the shifter in post #19 of the link I posted above.
LockDoc
Leon
