Old 02-25-2023, 06:06 PM   #1
Paul Y
Another question! Running speaker wires into the door.
Evening all,
Just come in from a few hours in the shed looking at how to get the speakers wires from the doors to the a pillar and then to the amp.
Conclusion is not sure how to do this! How have others run cables through the A pillar?
Over too you.
P.
Woody's Build -
http://67-72chevytrucks.com/vboard/s...d.php?t=658621
If it goes wrong, I blame the Internet...
Paul Y is offline   Reply With Quote
Old 02-25-2023, 11:23 PM   #2
62bagger
62bagger's Avatar
Re: Another question! Running speaker wires into the door.
I ran mine under the sill plate. Is the wire you are using too large to do that?
62bagger is offline   Reply With Quote
Old 02-26-2023, 02:40 PM   #3
The Rocknrod
Moderator
The Rocknrod's Avatar
Both speaker wire and power window wires - seems to me you'd have to drill at least two pieces of metal in the cab to get to the under dash area.
Old 02-26-2023, 04:16 PM   #4
Paul Y
That is my thinking Mr Rod.
Just looking to get some advice from somebody that has done it before and can give a few pointers.
P.
Woody's Build -
Old 02-27-2023, 04:39 PM   #5
forestb
forestb's Avatar
I used something like this
https://www.summitracing.com/parts/e...xoC0qkQAvD_BwE
For my power windows with a hole cut in the door and a hole cut in the door frame.
I originally bought something like this
https://www.summitracing.com/parts/k...RoC2cYQAvD_BwE
But it ran into too much under structure in the doors.
forestb is offline   Reply With Quote
Old 02-27-2023, 05:15 PM   #6
Paul Y
Thanks Forest.
Do you have a picture of the installation and what did you have to drill through to run the wires?
I think that is my biggest issue, the multiple holes that need to be drilled to get the cables through to under the dash!
Or an you go through the door strap holes, drill through from there and find a way to fish the cable up behind the dash.
Or I just stick the cable behind the weather strip and stop worrying about it….
P.
Woody's Build -
Old 02-27-2023, 10:35 PM   #7
forestb
forestb's Avatar
Originally Posted by Paul Y View Post
Thanks Forest.
P.
I don’t do the install myself. But if my memory serves me correctly he drilled a hole at the top of the boxed in part of the door jamb. He drilled it high enough that the wires came out and went right under the dash. No need for any holes in the dash. My truck is a 62 so how all those parts come together might be different on my truck. I can’t really take any photos right now because I have a broken foot and can’t crawl around down there right now.
Old 02-28-2023, 02:10 AM   #8
Paul Y
Thanks Forest and hope the foot heals up quickly.
P.
Woody's Build -
