I'm planning on adding a sway bar to 67 C15, I have read several post on here about using the 73-87 sway bars. Thinking I'm going to go this route I was wondering if a 3/4 ton saw var too much for only having a 6 cylinder?
![]() ![]() ![]() Join Date: Jan 2018
Re: Sway bar 67 C10
Nah, definitely not too much. Sway bars don't care what engine you have in it, they just care about how you drive it. If you like more stability around corners, you'll like the 3/4 ton bar
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
Re: Sway bar 67 C10
x2.
70+ ( Old Skool Club )
![]() Join Date: Nov 2003
Re: Sway bar 67 C10
I had the factory 7/8 inch sway bar on my truck but swapped it for a 1 1/4 bar from a 73-87 1 ton.
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
![]() Join Date: Jan 2003
Re: Sway bar 67 C10
I have a 1976 C20 frame I'm pulling the front sway bar (26mm) and putting it on my 1967
1969 ![]() 1950 Chevy Wagon 1978 Big 10 1967 C10, 250,3-OTT |
Tags |
1967 gmc, sway bar |
