Old 05-22-2023, 11:44 AM   #1
Bunky
Question Sway bar 67 C10
I'm planning on adding a sway bar to 67 C15, I have read several post on here about using the 73-87 sway bars. Thinking I'm going to go this route I was wondering if a 3/4 ton saw var too much for only having a 6 cylinder?
Bunky is offline   Reply With Quote
Old 05-22-2023, 10:28 PM   #2
cwcarpenter98
cwcarpenter98's Avatar
Re: Sway bar 67 C10
Nah, definitely not too much. Sway bars don't care what engine you have in it, they just care about how you drive it. If you like more stability around corners, you'll like the 3/4 ton bar
Christian Carpenter
Overdrive wiring here
1981 C10 - Penny 350, Saginaw 4 speed
Old 05-23-2023, 03:46 PM   #3
SCOTI
SCOTI's Avatar
Re: Sway bar 67 C10
x2.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 09-23-2023, 04:22 AM   #4
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
Re: Sway bar 67 C10
I had the factory 7/8 inch sway bar on my truck but swapped it for a 1 1/4 bar from a 73-87 1 ton.
1992 K1500 GMC Suburban
" In the end, we only regret the chances we didnt take "
" Time is the only currency we spend without knowing the balance, use it wisely ." ..
Old 10-01-2023, 12:12 AM   #5
Warrens69GMC
Warrens69GMC's Avatar
Re: Sway bar 67 C10
I have a 1976 C20 frame I'm pulling the front sway bar (26mm) and putting it on my 1967
1969 307, t350
1950 Chevy Wagon
1978 Big 10
1967 C10, 250,3-OTT
1967 gmc, sway bar
