02-05-2024, 07:48 PM | #1 |
Build sheet ?
Did Blazers assembled in California have build sheets and if so where?
02-05-2024, 09:35 PM | #2 |
Re: Build sheet ?
The build sheets weren't intended to be placed anywhere so it's random chance if you do.
They were supposed to be gathered up and thrown away at the end of the line like all the rest of the trash (coffee cups, extra screws, inspection tickets, etc). But if they were buried it was easier to just leave them where they lay and build the rest of the vehicle up around them. You are lucky if you find one. I've only found one in all of my (three or four) collector vehicles. There would have been several sheets used per vehicle: one for each sub assembly area that fed into the main line, so one for motor line, one for chassis line, axle line, one for body shop, one for soft trim, one for hard trim. As such - any place that supports those operations would be fertile ground. In the seat, under the carpet or floor trim, behind a headliner or A pillar trim, under the instrument panel top pad, behind door trim panels, on top of the fuel tank, stuck in a frame rail, inside a fender, etc. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ Last edited by Keith Seymore; 02-06-2024 at 06:14 PM. |
02-05-2024, 10:52 PM | #3 |
Re: Build sheet ?
I don’t think that Blazers were assembled in California. I believe they were only assembled in Flint and St Louis.
1972 Blazer Highlander 1971 GMC K1500 SWB (sold) 2004 Corvette Z06 CE |
02-05-2024, 11:04 PM | #4 | |
Re: Build sheet ?
Link: https://en.wikipedia.org/wiki/Chevrolet_K5_Blazer Model years 1969–1972 Assembly Flint Truck Assembly, Flint, Michigan St. Louis Truck Assembly, St. Louis, Missouri
