Old 02-05-2024, 07:48 PM   #1
kna4977
Build sheet ?
Did Blazers assembled in California have build sheets and if so where?
kna4977 is offline   Reply With Quote
Old 02-05-2024, 09:35 PM   #2
Keith Seymore
Keith Seymore's Avatar
Re: Build sheet ?
The build sheets weren't intended to be placed anywhere so it's random chance if you do.
They were supposed to be gathered up and thrown away at the end of the line like all the rest of the trash (coffee cups, extra screws, inspection tickets, etc). But if they were buried it was easier to just leave them where they lay and build the rest of the vehicle up around them.
You are lucky if you find one. I've only found one in all of my (three or four) collector vehicles.
There would have been several sheets used per vehicle: one for each sub assembly area that fed into the main line, so one for motor line, one for chassis line, axle line, one for body shop, one for soft trim, one for hard trim.
As such - any place that supports those operations would be fertile ground. In the seat, under the carpet or floor trim, behind a headliner or A pillar trim, under the instrument panel top pad, behind door trim panels, on top of the fuel tank, stuck in a frame rail, inside a fender, etc.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 02-05-2024, 10:52 PM   #3
tim71
tim71's Avatar
Re: Build sheet ?
I don’t think that Blazers were assembled in California. I believe they were only assembled in Flint and St Louis.
1972 Blazer Highlander
1971 GMC K1500 SWB (sold)
2004 Corvette Z06 CE
tim71 is offline   Reply With Quote
Old 02-05-2024, 11:04 PM   #4
Getter-Done
Getter-Done's Avatar
Re: Build sheet ?
Wiki a Ped Ia backs you up on that Tim.
Link: https://en.wikipedia.org/wiki/Chevrolet_K5_Blazer
Model years 1969–1972
Assembly Flint Truck Assembly,
Flint, Michigan
St. Louis Truck Assembly,
St. Louis, Missouri
84 Chevy K-20
