07-28-2024, 11:25 AM | #1 |
Fixed Something That's Always Bothered Me 67-72 C10
Hello, I finally got around to fixing something that's always bothered me when I drive my truck. It's the small details that make the difference and make these trucks more enjoyable to drive!
The stock gas pedal is recessed 3+ inches down from the brake pedal, causing my shoes to get stuck behind the brake pedal and just generally annoying me when I take it out, especially when off 4 Wheeling over technical terrain. Solution, get a used chevy pedal off the flea-bay and use the TIG welder to put the pedal in the position it should have been from the factory. I considered a Lokar pedal but it didn't have the range to put the pedal in the best possible location. My TIG welder, some 3/8 steel rod and time allowed my to place it literally anywhere. I think the stock pedal may not have been opening the secondaries all the way as well, confirmed they do now. See pictures below! Last edited by beanious; 07-28-2024 at 11:37 AM. |
07-28-2024, 11:34 AM | #2 |
Re: Fixed Something That's Always Bothered Me 67-72 C10
Stock on the left, Modified on the right.
Stock Height 1 Stock Height 2 Modified Height 1 Modified Height 2 |
07-28-2024, 11:54 AM | #3 |
That pedal design was utilized from 1971-72. The 1967-70 design was awful on a couple of fronts. The pedal would wear, and then would not be retained by the ball studs on the floor. Also, if the engine mount would break, the engine would rise and jamb the throttle wide open.
I switched to the 1971-72 suspended pedal/cable throttle on my 1970 Blazer for the reasons mentioned above. Great job on the mod!
1970 K/5 Blazer CST 4WD, Medium Bronze, 93k ACT. miles, 350, 4 speed, rear positraction, 16.5" x 8.25" HD wheel option, tilt, tach, vacuum, AM/FM, manual throttle...Dad ordered and purchased new 4/70. Currently frame off restoration finally getting close to completion.. 1972 Cheyenne Super 20 2WD, DK Blue/White, 90K ACT. miles, 402, TH400, 4.10 open, tilt, tach, vacuum, A/C, AM/FM, manual throttle.. A mostly original paint never rusted Texas survivor... 2017 Sierra 1500 SLT 4WD, Black, 45k miles, 5.3, 6L80E, 3.42 LS, 20" polished wheels, everything but moonroof and 6.2... 2019 Canyon SLT 4WD, White, 62k miles, 3.6, 8L45, 3.23 LS, 18" wheels |
07-28-2024, 11:59 AM | #4 |
You could teach the Cybertruck engineers a thing or two !
71 C-20 07 Magnum RT AWD |
07-28-2024, 01:10 PM | #5 |
Who Changed This?
One could also lower the brake pedal. I suspect that the only reason that the brake pedal is so high up is so that it matches (pretty much) the clutch pedal height. There's no other real reason I can think of for it.
beanious- did you verify that the pedal is at the floor when the carb is at WOT? I've seen carbs with the stop bent and the primary throttle plates could actually go over-center in that case.
07-28-2024, 01:36 PM | #6 |
54blackhornet, that's awesome Cybertruck
I wish I could work on those, sometimes problems can be fixed cheaply and last a long time, right! Last edited by beanious; 07-28-2024 at 01:45 PM. |
07-30-2024, 01:37 PM | #7 |
That's something I've thought about doing because I'm tall and the pedal is too high. But it's definitely a PITA with the pushrod nestled in the bracket. However, I had to mess with it when I converted to power brakes 30 years ago, but I was much younger!
Mike 1969 C10 LWB -- owned for 35 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. 1982 C10 SWB -- sold 1981 C10 Silverado LWB -- sold, but wish I still had it! 1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! |
07-29-2024, 11:10 AM | #8 |
>>, especially when off 4 Wheeling over technical terrain.<<
Unless you have a size 16 boot, I don't see how you could operate that accelerator pedal in rough terrain. People generally rest their heel on the floor for stability, as the gas pedal is relatively easy to operate at any position between top and bottom. Is your brake pedal is in the correct position with the rubber stop, at the top of the pedal arm? With that raised gas pedal, it would be EXTREMELY uncomfortable for me. With my manual trans,I would really hate getting my foot off the brake pedal on a hill and getting to the gas. Imported cars from counties where people have little feet often have all three pedals lined up at the same height. My C4 had pedals at different heights, with the clutch higher, but they were very close together. You couldn't drive it with work boots. IMO
'67 GMC 2500, 292, 4spd, AC |
07-29-2024, 12:27 PM | #9 |
It all comes down to personal preference really. Not everyone wants to keep their vehicle stock, I take my truck across the Rubicon Trail, something most people don't do. The ability to easily transition from brake to gas and also gas to brake seamlessly is what I desired and accomplished. On to the next modification
07-30-2024, 07:50 AM | #10 |
Might I make a suggestion. If you're not running shoulder belts, fill those holes! Very bright push in led's for some mood lighting.
07-30-2024, 09:06 AM | #11 |
Yuccales, that's pretty cool. Did you use 3/4" LEDs, where'd ya get them from?
07-30-2024, 09:21 AM | #12 |
I’m 5’11” and I feel the gas pedal is to close to me at times specially after I have been driving the 85 for a while. But I guess it’s all subjective to what you like and feel comfortable with.
Mark 72 c20 custom camper Husky edition, 66 SS396 Chevelle 1964 Hawk, 63 Avanti,62 lark 1969 AMX , 1968 c20 stepside ,85 K20 1977 Suburban sold 68 anniversary. |
07-31-2024, 07:30 AM | #13 |
