Old 07-28-2024, 11:25 AM   #1
beanious
Post Fixed Something That's Always Bothered Me 67-72 C10
Hello, I finally got around to fixing something that's always bothered me when I drive my truck. It's the small details that make the difference and make these trucks more enjoyable to drive!
The stock gas pedal is recessed 3+ inches down from the brake pedal, causing my shoes to get stuck behind the brake pedal and just generally annoying me when I take it out, especially when off 4 Wheeling over technical terrain.
Solution, get a used chevy pedal off the flea-bay and use the TIG welder to put the pedal in the position it should have been from the factory. I considered a Lokar pedal but it didn't have the range to put the pedal in the best possible location. My TIG welder, some 3/8 steel rod and time allowed my to place it literally anywhere.
I think the stock pedal may not have been opening the secondaries all the way as well, confirmed they do now.
See pictures below!
beanious is offline   Reply With Quote
Old 07-28-2024, 11:34 AM   #2
beanious
Re: Fixed Something That's Always Bothered Me 67-72 C10
Stock on the left, Modified on the right.
Stock Height 1
Stock Height 2
Modified Height 1
Modified Height 2
Old 07-28-2024, 11:54 AM   #3
1970cstblazer
1970cstblazer's Avatar
Arrow Re: Fixed Something That's Always Bothered Me 67-72 C10
That pedal design was utilized from 1971-72. The 1967-70 design was awful on a couple of fronts. The pedal would wear, and then would not be retained by the ball studs on the floor. Also, if the engine mount would break, the engine would rise and jamb the throttle wide open.
I switched to the 1971-72 suspended pedal/cable throttle on my 1970 Blazer for the reasons mentioned above.
Great job on the mod!
1970 K/5 Blazer CST 4WD, Bronze, 93k ACT. miles, 350, 4 speed, positraction, 16.5" x 8.25" wheel option, tilt, tach, vacuum, AM/FM, manual throttle...Dad ordered and purchased new 4/70. Currently frame off restoration in progress...
1972 Cheyenne Super 20 2WD, DK Blue/White, 90K ACT. miles, 402, TH400, 4.10 open, tilt, tach, vacuum, A/C, AM/FM, manual throttle.. A mostly original paint never rusted Texas survivor...
2017 Sierra 1500 SLT 4WD, Black, 41k miles, 5.3, 6L80E, 3.42 LS, 20" polished wheels, everything but moonroof and 6.2...
2019 Canyon SLT 4WD, White, 60k miles, 3.6, 8L45, 3.23 LS, 18" wheels
Old 07-28-2024, 11:59 AM   #4
54blackhornet
54blackhornet's Avatar
You could teach the Cybertruck engineers a thing or two !
71 C-20
07 Magnum RT AWD
54blackhornet is offline   Reply With Quote
Old 07-28-2024, 01:10 PM   #5
Steeveedee
Who Changed This?
Steeveedee's Avatar
One could also lower the brake pedal. I suspect that the only reason that the brake pedal is so high up is so that it matches (pretty much) the clutch pedal height. There's no other real reason I can think of for it.
beanious- did you verify that the pedal is at the floor when the carb is at WOT? I've seen carbs with the stop bent and the primary throttle plates could actually go over-center in that case.
~Steven
Simi Valley, CA
Old 07-28-2024, 01:36 PM   #6
beanious
54blackhornet, that's awesome Cybertruck
I wish I could work on those, sometimes problems can be fixed cheaply and last a long time, right!
Old 07-28-2024, 01:45 PM   #7
beanious
Steeveedee,
It's an automatic, I'm happy with the brake pedal height, perfectly adjusted for at rest and throw. After installed I checked the full throttle to make sure I can't push the carb linkages past full open and bend rods etc. Perfect throttle idle height and perfect full throttle throw with the pedal on the floor.
Old 07-28-2024, 03:42 PM   #8
Steeveedee
Who Changed This?
Steeveedee's Avatar
Thumbs up Re: Fixed Something That's Always Bothered Me 67-72 C10
Originally Posted by beanious View Post
Steeveedee,
~Steven
Simi Valley, CA
Old 07-29-2024, 11:10 AM   #9
RichardJ
>>, especially when off 4 Wheeling over technical terrain.<<
Unless you have a size 16 boot, I don't see how you could operate that accelerator pedal in rough terrain.
People generally rest their heel on the floor for stability, as the gas pedal is relatively easy to operate at any position between top and bottom.
Is your brake pedal is in the correct position with the rubber stop, at the top of the pedal arm?
With that raised gas pedal, it would be EXTREMELY uncomfortable for me. With my manual trans,I would really hate getting my foot off the brake pedal on a hill and getting to the gas.
Imported cars from counties where people have little feet often have all three pedals lined up at the same height. My C4 had pedals at different heights, with the clutch higher, but they were very close together. You couldn't drive it with work boots. IMO
'67 GMC 2500, 292, 4spd, AC
RichardJ is offline   Reply With Quote
Old 07-29-2024, 12:27 PM   #10
beanious
It all comes down to personal preference really. Not everyone wants to keep their vehicle stock, I take my truck across the Rubicon Trail, something most people don't do. The ability to easily transition from brake to gas and also gas to brake seamlessly is what I desired and accomplished. On to the next modification
Old 07-30-2024, 07:50 AM   #11
yuccales
yuccales's Avatar
Might I make a suggestion. If you're not running shoulder belts, fill those holes! Very bright push in led's for some mood lighting.
yuccales is offline   Reply With Quote
Old 07-30-2024, 09:06 AM   #12
beanious
Yuccales, that's pretty cool. Did you use 3/4" LEDs, where'd ya get them from?
Old 07-30-2024, 09:21 AM   #13
72c20customcamper
72c20customcamper's Avatar
I’m 5’11” and I feel the gas pedal is to close to me at times specially after I have been driving the 85 for a while. But I guess it’s all subjective to what you like and feel comfortable with.
Mark
1969 AMX ,
1968 c20 stepside ,85 K20
1977 Suburban sold
68 anniversary.
Old 07-30-2024, 01:37 PM   #14
MikeB
MikeB's Avatar
That's something I've thought about doing because I'm tall and the pedal is too high. But it's definitely a PITA with the pushrod nestled in the bracket. However, I had to mess with it when I converted to power brakes 30 years ago, but I was much younger!
Mike
1969 C10 LWB -- owned for 35 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, AAW wiring harness, 5-lug conversion, 1985 spindles and brakes.
1982 C10 SWB -- sold
1981 C10 Silverado LWB -- sold, but wish I still had it!
1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming.
Retired as a factory automation products salesman.
Worked part-time over the years for an engine builder and a classic car repair shop.
Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then!
MikeB is offline   Reply With Quote
Old 07-31-2024, 07:30 AM   #15
yuccales
yuccales's Avatar
Got them at NAPA. Sorry I did not save the part #. What worked out good ,was the threads in the holes bit into the rubber to hold them there.
Old 07-31-2024, 08:29 AM   #16
72c20customcamper
Looking at your before pictures the gas peddle looks extremely low in relation to the brake peddle . Mine isn’t like that at all it’s a little lower but not like yours . I’ll snap a picture before I leave for Carlisle this morning
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
