Old 12-17-2024, 12:24 AM   #1
72 k15
72 k15's Avatar
68 K20 rubbing on pitman arm.
I’m curious if this is the correct pitman arm for my 68 k20? Only has 8 inch wide tires on factory rims and it and is rubbing on pitman arm nut. I’ll post some pictures, but everything is factory including closed knuckle axle. Or is it as simple as the axle steering limiter bolt needs to be adjusted? Also worried for when I am going to 10" tires this summer.
1959 GMC 100 3 on the tree 270.
1968 GMC k2500 Stepside
1972 Chevy Monte Carlo Custom.
72 k15 is offline   Reply With Quote
Old 12-17-2024, 09:11 PM   #2
my04
my04's Avatar
Re: 68 K20 rubbing on pitman arm.
Looks the same as my '68 K20.
Dana 44 closed knuckle axle.
285/75 16 tires on 6.5" rims.
No rubbing. I have never looked with the steering cranked to see how close it is though.
Might be as simple as adjusting the stop bolt that you mentioned. The turning radius of these trucks is like a school bus.
1966 Custom Camper -327, 3OTT
1968 Chevrolet K20 - 350, 4 speed
1972 K10 SWB - 400, 3OTT
2003 Corvette Z06 - LS6 350, 405HP
2004 Tahoe LT
2015 Silverado 2500HD - 6.0L V8
my04 is offline   Reply With Quote
Old 12-17-2024, 10:14 PM   #3
72 k15
72 k15's Avatar
Thanks, that's what I was thinking. What rims are those on your k20?
Old 12-18-2024, 09:44 PM   #4
my04
my04's Avatar
Rims are just factory square body 3/4 ton wheels.
2004 Tahoe LT
Old 12-19-2024, 10:29 AM   #5
Dashman
Active Member
Is the frame twisted counter clockwise, looking from front to back? That might cause the drag link nut to stick out more. What if you placed some washers between the steering box and frame at the top? Is the pitman arm on the correct spline? Is your turning radius the same to both sides? If the above is ok, then it's probably an over zealous limiter like you suspected.
Dashman is offline   Reply With Quote
