Bench Seat measurements
Question for you guys reguarding factory bench seats..
I got lowback seats in my 69, not sure what they’re from they were installed in the truck when I bought it, but I’d like to swap to a bench so I can take my lady and my son at the same time. My issue is that the previous owner also installed a floor shifter so I’m looking for a measurement of the back of the cab to the very front of the bench seat to see if I’ll be able to fit one without moving the shifter. I do not have the gas tank in the cab it’s been relocated to the rear. Any input would be great
69 C10 "Nosejob" 24 Raptor "Daily duty" |
![]() Join Date: Jun 2005
Re: Bench Seat measurements
I can get a measurement after work today, but I still have the tank behind the seat. Also, do you want the measurement with the seat all the way back?
70 C/10 SWB 402/TH400/3.73 "The Needy Beast" 200,000 Mile Club Disc Brake Club Owner installed options: Front Sway Bar Power Steering Power Brakes Cigar Lighter Courtesy Lights Deluxe Side Markers Wiper Delay Sliding Rear Window Power Windows Power Locks Sniper EFI 2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear |
Yea please! Anything would help!
Ok I will take a measurement when I get home and post it here. Do you want the measurement from the back wall of the cab to the front of the bottom cushion?
Yes, the back of the cab behinds gas tank to wherever the front of the actual seat would end
Keep in mind the seats usually hit the panel above tank and below rear window before it hits the tank.
2001 Silverado K-1500 2005 FXDWG stage3 69 CHEVY Short/Step 327/4L60 373 posi 63 IMPALA 327/4L60 |
I measured on the right side of the seat so the tank is not in the way. I got 29” from the back of the cab to the front edge of the bottom seat cushion. The seat is non-folding with it all the way back. You’re right the back of the seat at the top does hit the cab before it hits the tank.
I have a Muncie M21 and a bench seat in mine. Not sure what trans you’re running but I could take some measurements of the shifter location in relation to the seat if that would help. The Muncie shifter location sits pretty far back but it clears the bench without issues.
Posted via Mobile Device |
Measurement from the dash to the seat (I still have the tank in the cab so it’s hard to get those numbers, but you can see where the shifter lands)
67 Short Step - 454 & Muncie 4-speed |
#10 | |
Also for height of seat if you measure from a point on the seat ( either the seat part, or top of back part ) to the inside of the roof, or a point on the dash. I eventually figured this out after trying to measure from the floor to the top and front of the seat with it installed. You know the cabs are all the same. Using the points I mentioned are more accessible with nothing in the way. If installing a non stock seat, with the seat removed you can then measure from your reference points ( dash, roof, whatever ) to the floor to figure out whatever mounting hardware modifications you have to do.
I got a bench seat baby, you don't have to sit over there. |
Perfect thank you guys!
| Bookmarks |
| Thread Tools | |
| Display Modes | |
