Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > S10 S15 Luv Blazer
Old 01-07-2025, 04:51 PM   #1
DPowers
One foot in front of the other
DPowers's Avatar
2000 S10 Blazer RPO code decipher
Have a '00 2wd/2dr Blazer
4.3 with 5 speed manual.
Im trying to decipher which code in the glovebox designates rear end size and gear ratio.
Need to replace axle bearings.
DPowers is online now   Reply With Quote
Old 01-07-2025, 06:22 PM   #2
Keith Seymore
Keith Seymore's Avatar
Re: 2000 S10 Blazer RPO code decipher
Rear end size is not dictated by an RPO code, but by the model.
So an S10 back then would be either a 7.625 or 8.5/8.6" ring gear 10 bolt (page 45 of the pickup document).
Pickup info packet: https://www.gm.com/content/dam/compa...rolet-S-10.pdf
I think you'll have to post up a photo of the cover so we can tell.
Ratio will be a "G" code, where
GQ1 = base ratio (the ratio itself will not specified on the SPID)
If an optional ratio was chosen it will appear on the SPID:
GU4 = 3.08
GU6 = 3.42
GT4 = 3.73
G80 = Locking/Limited Slip (non-open diff)
for example.
Blazer info packet: https://www.gm.com/content/dam/compa...let-Blazer.pdf
You might also post a pic of the SPID, for reference.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 01-07-2025, 09:05 PM   #3
DPowers
DPowers's Avatar
GU4 = 3.08
GU6 = 3.42
GT4 = 3.73
for example.
K
Great and helpful info you have provided. Appreciate it.
Has code of GU6-3.73 and G80- Limited slip.
Will have to crawl under it and do some measuring
Old 01-07-2025, 10:47 PM   #4
44th Miss Inf
Grabbed these off the S10 LS Swap site. Easy way to tell the 7.5 vs the 8.5/8.6 rear in an S10 platform
44th Miss Inf is offline   Reply With Quote
Old 01-07-2025, 11:12 PM   #5
Keith Seymore
Perfect. Thank you for that -
K
1979-1986
1986 - 2019
Old Yesterday, 12:50 AM   #6
DPowers
DPowers's Avatar
Excellent
