Yesterday, 08:36 PM | #1 |
Junior Member
Location: Clarkdale, Arizona in a van down by the river
Recommend me a LED light kit
Is there a recombed LED light kit for the all the marker and tail lights that is quality and bright and that will last, oh and that is pretty much plug and play?
I would like brighter tail lights especially becuse other drivers around here SUCK lol
Freedom isn't safe, it requires you to take responsibility for your own life, your own safety, and your own success. It carries with it the possibility of failure and the understanding that you're working without out a safety net. If you give the state the responsibility for any of these you also give up the freedom that accompanies the responsibility. |
Yesterday, 11:02 PM | #2 |
Who Changed This?
Re: Recommend me a LED light kit
You might look into a headlight relay kit first. I put one on my truck and it made a huge difference. The headlight current doesn't go through the switch, so there's a lot less voltage drop, and all the other lights are brighter, as a result. Check it out-
https://67-72chevytrucks.com/vboard/...d.php?t=782071 As for brighter brake lights, unless you have flamethrowers, people are gonna be stupid behind you, anyway. People tailgate the H*** out of me, even when I'm speeding. I guess they like the fumes?
Today, 12:08 AM | #3 |
I always told my kids nobody tailgates a 70's car, but there's no accounting for personal preference ;-)
1970 C10 Custom longbed 350/350 Code:
__ ______|__]\____ ....|___(o)_____(o)_] |
Yesterday, 11:13 PM | #4 |
I recommend the headlight relay as above concerning your headlights. As for all the other lights, I really like the quality of the United Pacific branded lights and run their front marker lights myself and have helped friends install them everywhere else. I went through just about every ebay/amazon LED bulb there was before finally going that way. Just make sure you get LED flashers with the ground wire or else you'll quickly find your blinkers and hazards don't work.
Today, 12:10 AM | #5 |
Junior Member
Damn, this site costs me more money and time every time I ask a question
Today, 02:11 AM | #6 |
Location: Herculaneum MO (20 minutes south of St. Louis
That's not quite true. They told you on another thread not to buy an aluminum radiator & dual fans for your 402.
67 C10 283 T5 swapped longbed fleetside = wife's daily driver 67 C20 292 (originally a 250)4speed longbed fleetside w/original wooden bed=my project truck 67 C10 283+.060 (so a 292 as well)T5 swapped longbed fleetside=my DD 72 C1500 Sierra Grande 350 TH350 longbed fleetside=wife's fair weather truck Can you tell we are fans of longbed fleetsides & 67s Chris |
Today, 01:36 AM | #7 |
Believe you have a 72. Note that problems will occur with front turn/running and side marker lights with led bulbs installed. ie- no lights or flashing. It has to do with how the side markers are grounded through the front turn bulbs. Side markers alternate flash with front turn on 71/72 trucks. Wiring changes and relays or diodes may be implemented to make led's work. Easiest solution for folks that want led is to direct ground the side front markers and eliminate the side flashing like the 69/70 trucks.
Richard 1972 K10 Custom Deluxe SWB Fleetside My build https://67-72chevytrucks.com/vboard/...d.php?t=800746 Last edited by Richard; Today at 02:13 AM. |
Today, 08:48 AM | #8 |
I have LED lights in the rear and they work great! They are United Pacific. Yes, they are bright! I also put led bulbs everywhere else and bought a blinker switch for LED bulbs, so everything works there also.
When I first installed the rear lights, something didn't work and I had to hook up a relay for the tail lights. I do not recall what it was, but I am thinking it was the cruise control. |
