Old 02-02-2025, 08:36 PM   #1
IT Cowboy
IT Cowboy's Avatar
Recommend me a LED light kit
Is there a recombed LED light kit for the all the marker and tail lights that is quality and bright and that will last, oh and that is pretty much plug and play?
I would like brighter tail lights especially becuse other drivers around here SUCK lol
1972 C10 Custom Deluxe Highlander 402
Freedom isn't safe, it requires you to take responsibility for your own life, your own safety, and your own success. It carries with it the possibility of failure and the understanding that you're working without out a safety net. If you give the state the responsibility for any of these you also give up the freedom that accompanies the responsibility.
IT Cowboy is offline   Reply With Quote
Old 02-02-2025, 11:02 PM   #2
Steeveedee
Ram-A-Lam-A-Ding-Dong
Steeveedee's Avatar
Re: Recommend me a LED light kit
You might look into a headlight relay kit first. I put one on my truck and it made a huge difference. The headlight current doesn't go through the switch, so there's a lot less voltage drop, and all the other lights are brighter, as a result. Check it out-
https://67-72chevytrucks.com/vboard/...d.php?t=782071
As for brighter brake lights, unless you have flamethrowers, people are gonna be stupid behind you, anyway. People tailgate the H*** out of me, even when I'm speeding. I guess they like the fumes?
~Steven
Simi Valley, CA
Old 02-02-2025, 11:13 PM   #3
67ChevroletDude
67ChevroletDude's Avatar
I recommend the headlight relay as above concerning your headlights. As for all the other lights, I really like the quality of the United Pacific branded lights and run their front marker lights myself and have helped friends install them everywhere else. I went through just about every ebay/amazon LED bulb there was before finally going that way. Just make sure you get LED flashers with the ground wire or else you'll quickly find your blinkers and hazards don't work.
67ChevroletDude is offline   Reply With Quote
Old 02-03-2025, 12:08 AM   #4
Rust_never_sleeps
Rust_never_sleeps's Avatar
Originally Posted by Steeveedee View Post
.... People tailgate the H*** out of me, even when I'm speeding. I guess they like the fumes?
I always told my kids nobody tailgates a 70's car, but there's no accounting for personal preference ;-)
1970 C10 Custom longbed 350/350
“Carburetors are forgiving, timing is not” — Thunderhead289
Rust_never_sleeps is offline   Reply With Quote
Old 02-03-2025, 12:10 AM   #5
IT Cowboy
IT Cowboy's Avatar
Damn, this site costs me more money and time every time I ask a question ��
Old 02-03-2025, 01:36 AM   #6
Richard
Believe you have a 72. Note that problems will occur with front turn/running and side marker lights with led bulbs installed. ie- no lights or flashing. It has to do with how the side markers are grounded through the front turn bulbs. Side markers alternate flash with front turn on 71/72 trucks. Wiring changes and relays or diodes may be implemented to make led's work. Easiest solution for folks that want led is to direct ground the side front markers and eliminate the side flashing like the 69/70 trucks.
Richard
Old 02-03-2025, 02:11 AM   #7
67 twins
Location: Herculaneum MO (20 minutes south of St. Louis
That's not quite true. They told you on another thread not to buy an aluminum radiator & dual fans for your 402.
67 C10 283 T5 swapped longbed fleetside = wife's daily driver(divorced)
67 C20 292 (originally a 250)4speed longbed fleetside w/original wooden bed=my project truck
67 C10 283+.060 (so a 292 as well)T5 swapped longbed fleetside=my DD(Sold)
72 C1500 Sierra Grande 350 TH350 longbed fleetside=wife's fair weather truck(divorced)
73 El Camino SS 454 4 speed my first big block
Can you tell we are fans of longbed fleetsides & 67s
Chris
67 twins is offline   Reply With Quote
Old 02-03-2025, 08:48 AM   #8
Joyridin
I have LED lights in the rear and they work great! They are United Pacific. Yes, they are bright! I also put led bulbs everywhere else and bought a blinker switch for LED bulbs, so everything works there also.
When I first installed the rear lights, something didn't work and I had to hook up a relay for the tail lights. I do not recall what it was, but I am thinking it was the cruise control.
Joyridin is offline   Reply With Quote
Old 02-06-2025, 05:27 PM   #9
Casper42
Casper42's Avatar
1. headlights: Holley Retrobright (link) the come in three colors, bright white, classic and yellow (I have classic)
2. Tail lights and front bumper marker: Amazon (link) get amber for front and red for the back
3. Side Marker: Amazon (link)
this set up took trial and error to get everything to work. Over the course of months, I purchased about eight different 1157 bulbs. This is the ONLY way I could get my front marker and the front side marker lights to work together without having professional electrical work done. Like others mentioned, you'll still need TWO flasher relays in your fuse panel at the kick panel. One for the turn signals and the second for the hazard lights.
This set-up is also the brightest bulbs that I could find that work well. I have had these for two years and no issues, and LOVE them. Everything is BRIGHT, particularly the headlights - just like a new car's LED headlights. Don't let the price fool you. They are well worth the value.
'72 C10 Cheyenne SWB North Carolina kept for 50 years, 75k original miles, Medium/Hawaiian Blue paint, 3 owners - one for 40 years & garaged kept. Original: sheetmetal, undercarriage, moldings, glass, immaculate unrestored bed.
New - rebuilt engine at 65k in 2015, one frame-on respray in 2010, front bumper, blue houndstooth seat, carpet, 8 inch rally wheels on 275-60R-15, LED lighting. - Semper Paratus!
Casper42 is offline   Reply With Quote
Old 02-06-2025, 08:45 PM   #10
dmjlambert
dmjlambert's Avatar
I recommend conventional incandecent bulbs for every bulb on the truck. The warmth and classic look can't be beat. Exception is the tail lights where the advantage of LED is the instant-on for brakes. The sooner the person tailgating you sees the brake light, the better. For those 2 bulbs this is what I use.
https://www.amazon.com/dp/B082WNNQ3W?th=1
Old 02-06-2025, 10:14 PM   #11
46stude
On my '72 Cheyenne, I upgraded to the LED taillights, but left the side markers and front blinker bulbs as-is. As noted above, the '71-'72s are a little trickier to change over, and as far as I'm concerned, the old school bulbs in those applications are more than adequate. Especially if the lenses are in good shape (like yours seem to be in the pics posted here in the other thread).
I do plan on the relays for the headlights, and probably a swap to the halogen or LED buckets.
46stude is offline   Reply With Quote
Old 02-06-2025, 11:18 PM   #12
IT Cowboy
IT Cowboy's Avatar
On my Tundra truck I have the 3rd brake light on the cab that pulses when the brake is hit, I call it the 3rd wife light
I also have the rope light stop and turn under the tailgate but I havent decided how that would look on and old truck.
Old 02-13-2025, 02:24 PM   #13
chappys4life
I did hella bulbs/lights with a relay harness. Night and day difference.
chappys4life is online now   Reply With Quote
Old 02-13-2025, 03:23 PM   #14
Sheepdip
Sheepdip's Avatar
I have the cargo lamp LED board that acts both as a lamp and a third brake light. The name slips me, but I believe the member of this forum who made them up was in Texas. Works very well, just run an extra wire from your stop light switch up to your cargo lamp.
Went back and found him, looks like he hasn't been active since 5/24
http://www.67-72chevytrucks.com/vboa...rd+brake+light
Sheepdip is offline   Reply With Quote
Old 02-14-2025, 08:59 PM   #15
IT Cowboy
IT Cowboy's Avatar
I tried these bulbs and the tails and all 4 corners work great. I am not able to make the turn signals flash when I put in the front amber bulbs. The recommended flasher modules seemed to do nothing at all towards helping. I left all the LEDs but put the front ambers back in and the rears and markers lights work and flash. I have the flasher modules that have the ground wires on them.
