Junior Member
![]() Join Date: Oct 2023
Headlights and turn signals only ?
Happened all at once ,no park lights, no brake lights , no dome light , no dash lights ???
Only headlights and turn signals working .Reached under dash, wiggled light switch n wires,, same for ignition switch, bulkhead connectors , headlight connectors , ground wires 3 I could find Voltage regulator. All fuses ok Does this seem like a light switch problem. The brake light thing is huge, can't drive without them. Also been doing the search thing on here last 2 hours And I just got the LMC headlight relay harness , not yet installed. 71 C 50 292 4sp 2sp vacuum operated rear end. Looking for wisdom and knowledge advice help. Any and all input welcome. Thanks in advance. Good luck on all your projects. |
#2 | |
![]() Join Date: Oct 2015
Re: Headlights and turn signals only ?
I agree with old51sedan's advice. Double check your grounds... the flow of electrons is no longer continuous.
![]() Join Date: Feb 2002
On a '67 K/10 Suburban, I had some weird issues with Taillights and some signal lights acting up.
['67s have no Side Markers or side lights.] When I put in a new Turn Signal Switch, all those gripes went away. Ground Straps are every bit as important as the above Posters say. You can drive your truck without Brake Lights legally, if you use the old standard Hand Signals. Arm out, bent down, Palm rear means Stop. Repeated motions from medium high, downward means Slowing. My Turn Signal lever came out -- lost screw -- from my Steering Column on the '68 C/10 Stepside.* I've been using old school hand signals for a couple years. For better visability at nigt, I wear a construction safety glove -- Orange/White with White 3M reflector strips for my signalling hand. Cops have routinely been on my 6 o'clock. None of them had a problem with it. [* I'll put the Column all back together when I get the right color Fawn paint for my repaired Steering Wheel. Also need a bearing in the column. Otherwise the Horn circuit is constantly energized.]
Every 25 years I like to rebuild that 292, whether it needs it or not. Last edited by '68OrangeSunshine; 03-05-2025 at 07:02 PM. |
#5 | |
Junior Member
Amazing what a test light will tell you, checked fuse panel n fuses , wasn't blown but wasn't making good connection, while trying to wiggle fuse it broke, put new fuse in . Yeah ,really sucks when you panic and put up a help request on a forum and it's as simple as a blown fuse , makes you feel really stupid .
Thanks to all who replied, good luck on all your projects. |
#7 | |
![]() Of course I don't have any answers but it's fun to listen to those that do. ...gotta throw in a picture just because. ![]() |
As my Drill Instructor said, ''The only Stupid Questions are the ones you're afraid to ask.''
![]() Join Date: Feb 2022
I often will start to formulate a question to post, and while doing so, come up with a alternate solution that sometimes works. I really struggle with reading and writing. I speculate me having to change up my thoughts to write a comprehensible sentence also fires alternate ideas in my melon. Good to see the problem was not really a problem.
Msgt USAF Ret
![]() ![]() Join Date: Jan 2005
If only we had an electrical section on the forum.
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
