Old 03-16-2004, 12:18 PM   #1
MrGoodpliers
MrGoodpliers's Avatar
'69 307: Large or small journal?
I have an anemic 307 in the beater. If my memory serves me, sbc's used small journal cranks through '67, then large journal cranks '68-up. Is this correct? I'm thinking of using the rotating assembly (minus pistons of course) to build a 327. Just wanted to know which block to look for. Also, would this crank be cast or forged?
We made Oklahoma a little after 3, Randy & his brother Bob & my old GMC...
MrGoodpliers is offline   Reply With Quote
Old 03-16-2004, 02:33 PM   #2
da-burb
"Ochre Ogre"
da-burb's Avatar
cast iron, large journal crank
Bowtie Truck Stop Inc.
Mid-West GM Truck Restoration Parts Supplier
Your Key Parts, Auto Metal Direct, Dynacorn,
and Goodmark dealer.
like us @ www.facebook.com/BowtieTruckStop
1971 C-10 Suburban (Ochre)
1971 K-10 Suburban (Ochre)
1972 C-10 Suburban (Ochre)
1972 K-20 Suburban (Yellow- that just aint right!)
Springfield, Minnesota 56087
da-burb is offline   Reply With Quote
Old 03-18-2004, 02:46 AM   #3
67 SS
Re: '69 307: Large or small journal?
Do you mean which 327 block?It would be easier to find a 350 block to put it in.
67 SS is offline   Reply With Quote
Old 03-18-2004, 09:44 AM   #4
MrGoodpliers
Exactly. I just wanted to know if I needed a small-journal 327 block or a large-journal 327-350. Thanks.
Old 03-18-2004, 10:54 AM   #5
cochran63
cochran63's Avatar
If you build a 327 i have a set of SJ aluiminum rods i am selling.
Youth soon passes away, but immaturity can last a life time.
cochran63 is offline   Reply With Quote
Old 03-18-2004, 03:50 PM   #6
70heavy
I am also considering this with mine. 1968 + cranks are large journal. Your crank is cast nodular iron, and that is the only type for the 307. I would just find a good 350 block, as they are everywhere, although a 327 block of course, will work. Try to stay with a block earlier than 1986 unless you want to buy an adapter kit for a one to two piece rear main seal... This later block will have 4 tapped holes and a machined flat above the rear seal area.
The blocks are "basically" the same other then that with a common standard bore size of 4.001".
Watch for:
Dipstick on the side you want it.
Starter motor bolt patterns (2 different size flywheels were used)
Block with a casted number 10 over 20 by the camshaft bore is preferred as they have a high tin/nickel content which helps the block breathe and maintain a seal longer.
Good Luck
70heavy is offline   Reply With Quote
