Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical
Old 09-20-2013, 01:16 PM   #1
cajun chevy
cajun chevy's Avatar
1972 c10 voltage regulator installation
Wondering if the voltage regulator on my 72'c10 should be rubber mounted.
thanks.
cajun chevy is offline   Reply With Quote
Old 09-20-2013, 10:14 PM   #2
Wrenchbender Ret
Re: 1972 c10 voltage regulator installation
Yes. The rubber mounts are called Wellnuts. I believe they are 10-32 treads.
If you can't find some let me know. I have a few left.
Wrenchbender Ret is offline   Reply With Quote
Old 09-24-2013, 01:07 PM   #3
sKnNyPpY
sKnNyPpY's Avatar
nevermind, double post
Life is too long to go slow...
71 GMC 1500 Super Custom LWB
350/350 AC(replaced w/vintage air)/PS/PB
2.5 CPP Spindle, 1" CPP Drop Spring, CPP Front and Rear Sway Bars/DJM Flip, new General Spring KC 5 spring pack, HEI /IntReg Alt
20x8.5 OldSkools 5" BS, 275/45 Falkens
sKnNyPpY is offline   Reply With Quote
Old 09-24-2013, 05:07 PM   #4
cajun chevy
Thanks wrenchdender, I will try to find some.
Old 12-30-2013, 06:19 PM   #5
1972SUPERSB
1972SUPERSB's Avatar
Anyone have a pic to show how these rubber mounts are mounted to the regulator? Thanks
Jeff
1972 Cheyenne Super SWB 350, Auto, Bucket Seats w/Console, Tach, Factory A/C, P/S ,P/B, Tilt
1998 Chevy 1500 Ext Cab 5.7, Pewter w/blue interior
1972SUPERSB is offline   Reply With Quote
Old 12-31-2013, 11:14 PM   #6
ray_mcavoy
The "rubber mounts" don't mount to the regulator.
Like Wrenchbender said, the "rubber mounts" are Wellnuts. You stick the Wellnuts into the holes in the radiator support. Place the regulator in position, and insert the mounting screws through the holes in the regulator base, and thread them into the Wellnuts. As the screws are tightened, they cause the ends of the Wellnuts to expand and that keeps them from pulling back through the holes in the radiator support.
ray_mcavoy is offline   Reply With Quote
Old 12-31-2013, 11:15 PM   #7
1972SUPERSB
Thanks I got it mounted tonight. Worked great thanks
Jeff
