Pan Hard Bar - Bend
Anyone able to bend aftermarket Pan Hard bar to fit around girdle type differential cover. I do not feel confident enough to do on my own.
Thanks in advance for your help. Pappy 2 |
![]() Join Date: Oct 2014
Re: Pan Hard Bar - Bend
The problem you will have is by bending the bar you're making it shorter and you may not have enough adjustment on the threaded end to center the rear in the truck. I'd take that into consideration before bending it.
Phil "Money is only a tool to create and achieve what you want most in life" PayPal: rodnrudy@comcast.net |
![]() ![]() Join Date: Sep 2008
I think there is plenty of adjustment to cover the bend. It will take a press to bend it.
Yesterday I was installing that same Super Track Bar on a 67 and for some odd reason the mount on the frame did not align with the one on the trailing arm. I had a stock length adjustable bar on the shelf that used factory mounting, and ended up putting it on. I can't see why it won't work just as well, and with a 5" static drop I see no clearance problems.
A prebent bar would be the way to go if you want to stay with the lower mount.
![]() Join Date: Nov 2018
What he said^^^^^^^^^^^^^^^
I have had Addco build me 2 custom sway bars over the years, I provided them with a dimensioned drawing and they took it from there. |
![]() Join Date: Feb 2016
Are you wanting to bend a bar you already own? Then I agree with RodandRudy. I know CPP sells a prebent bar.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. ![]() RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
Thanks to all that replied, was not aware anyone made a pre-bent bar for this application, so I guess I will go that route. Anyone need a straight one.
Thank again, Pappy 2 |
ECE sells a pre-bent bar as well. It's what I used w/finned polished cover, fit great.
![]() ___________________________________________ '68 C10 true shortbed, LS swap restomod. '03 Z71 daily, '63 AMC Rambler V8 survivor |
Would it be possible to move the mounts back a ways?
