louvered cowl
louvered cowl:photo or picks, any one have one. as i think this could be a nice easy bolt on mod with fuction ( keeping the leaves out )
Re: louvered cowl
That would be pretty trick looking. Ill bump for pics...
Re: louvered cowl
i saw one of these back in the late 70's early 80's and i think it was a custom one off. that thread in the parts form of the solid fiberglass got the gray matter stirred up. so why not a lovered cowl in steel and you could paint 360o (no rust ). the search did'nt turn up much. 463
Insert Title Here
Re: louvered cowl
just weld it shut and have it louvered
BOBBY _69 SWB_ 1000 pics of 67-72's>> http://s193.photobucket.com/albums/z...-72/?start=all << |
Re: louvered cowl
i think i might pick up one do up the metal work on it and head over to the man with the metal stamping tool and back to paint. one off and i get the look i want. 463 slow typer
Insert Title Here
Re: louvered cowl
Mar-K sells these panels that are made to weld over the indent on the tailgates... maybe you could weld that in place of the opening on the cowl?
Re: louvered cowl
I know this is old... but who is this Mar-K he spoke of? Is this guy still around?
"Hey... its only time and money right? Just do it." 67 Short Bed under major construction http://67-72chevytrucks.com/vboard/s...=651356&page=8 |
#8 | |
![]() Join Date: May 2010
Re: louvered cowl
Old member
Measure the vents opening on your cowl and cut the metal to fit, take it have it stamped then weld it in place and have it painted.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
Re: louvered cowl
Thats not the design I would go for, plus I was looking for the whole cowl ready to install. Ive been doing enough welding patches, Im about sick of it.
![]() Join Date: Dec 2015
Re: louvered cowl
Here is my 2 cents worth, really easy to stick aluminum window screen under the grill, using whatever caulk. In my case, free, and I'm mechanically challenged.
1968 Long Bed 2016 Honda Civic Coupe EX-T ticket magnet |
Re: louvered cowl
Its not leaves Im worried about keeping out.. its finding something louvered to match the louvered visor I have...
