08-14-2013, 05:23 PM | #1 |
i got the original wood in the bed of my truck what can i do to protect it
the wood in the bed of my truck is in real good shape to be 46 years old what is good to put on it to keep it from wrought[ATTACH][/ATTACH]
08-14-2013, 05:57 PM | #2 |
Cluster King
Re: i got the original wood in the bed of my truck what can i do to protect it
Keep that canopy over the top of it is the best thing to do. That keeps it out of direct sun light which in time will cause the wood to shrink and crack. Keep it dry and try not to spill chemicals on it. You can paint it like the factory and that will help also.
You are lucky to have wood in that shape. It is rare to see. |
08-14-2013, 07:45 PM | #3 |
If the factory paint and the black perservative are gone you could use the time-honored motor oil treatment if the bed is to be exposed to the elements. It soaks in and around the wood and protects the metal. Mostly used oil was applied but new oil is a better choice.
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
08-14-2013, 08:06 PM | #4 |
On my trailer deck I use a mixture of about 50% linseed oil and 50% turpentine once a year. That's what we used on our grain trucks long ago. We saved the used motor oil to spray down the equipment each fall before storage.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
