06-19-2015, 02:09 PM | #1 |
Does anyone know this Blazer?
1961 Biscayne http://67-72chevytrucks.com/vboard/s...90#post6978790 SOLD 1971 C-10 http://67-72chevytrucks.com/vboard/s...d.php?t=656258SOLD 1966 Suburban http://67-72chevytrucks.com/vboard/s...85#post7323885 |
06-19-2015, 03:11 PM | #2 |
67-72 parts collector,…
Re: Does anyone know this Blazer?
SUPER NICE blazer.
Never seen it on the board before. What year is it suppose to be? (it has 69-70 rear seat and 71-72 front bucket upholstery)
06-19-2015, 03:55 PM | #3 |
I was told it was a 1970 that was swapped to a 1972.
What is the difference in the rear seat?
06-19-2015, 04:31 PM | #4 | |
(69-70 had the single scroll pattern in the center of each side) Rear seat looks like an original. The fronts look re done. I was going to guess 71-72. 72 door panels and 71-72 gas pedal arm. I would verify it's not a converted 4x4. Either way it's super nice!
06-19-2015, 03:56 PM | #5 |
I am hoping to trade my biscayne for it. I was hoping that there was a build thread on here somewhere.
The current owner did not build it. Ay ideas of what it is worth?
06-19-2015, 04:34 PM | #6 |
I would guess $30k-$40k for an original 2wd blazer.
1970 2wd blazers were 6-lug and 4-wheel DRUM brakes. So a few things have been changed. Should have a factory "low hump" floor also.
06-19-2015, 04:47 PM | #7 |
The info i have is:
1970 built as a 72 spring yellow ZZ350 GMPP Crate motor 700r4 Jasper trans. vintage air autosound radio tilt wheel CPP springs and spindles 4.5/5 no c notch Disc fronts, drum rear I have asked for a pic of the SPID.
07-10-2015, 07:40 AM | #8 | |
K5 blazer 4x4 but converting to 2wd and running a 68 front end, kinda wanted to run that pale yellow color. Don't they call that color butternut yellow also? Anyone with a paint code. That's a very nice blazer, would rather the top be white but that's jmo. Donnie
Things happen for a reason! |
07-10-2015, 07:50 AM | #9 | |
Did they come factory with a black or white top? I know you see alot more white tops.
06-19-2015, 04:56 PM | #10 |
The "cupholder" console is also a later model item,... but I consider that a plus!
If it was mine,... I would change the wheels and add K5 emblems to the fenders. Everything else looks very nice, from the pics you have posted. I would like to see the SPID also,...
06-19-2015, 07:03 PM | #11 | |
Those wheels are definatly not my favorite. Not sure what i would do, but they would have to go. I was told that the SPID was removed during the restoration by the PO. The first 6 of the vin is CE180S This should be if i am reading it correctly. 4x2 V8 1/2 ton blazer 1970 St. Louis This should verify that it is a factory 4x2. Just can not tell what all factory options were installed.
06-19-2015, 10:53 PM | #12 |
I am opposite. Those wheels are not bad at all for aftermarket. There are lots worse that I have seen. Those are the most "common" I'll say. I would not put any other emblems on it. It's clean without them.
-Keegan- '72 Jimmy 4x4 - 5.3/4L65E/NP205 swap http://67-72chevytrucks.com/vboard/s...d.php?t=663780 |
06-20-2015, 07:29 AM | #13 |
"NEVER SLOW DOWN, NEVER GROW OLD ".. Leave it alone, looks great can't see the wheels while your driving it anyway !
06-20-2015, 07:52 AM | #14 |
Looks like the one I saw at GoodGuys in Nashville last month.....looked really really nice.....
Would you send me a pm with selling price?........that truck had a lot of attention to detail as you can tell from pictures Value?.........there is 30-40 K in that truck easy......
1970 2WD Blazer 454 1972 C-10 Extended Cab 350 SBC Last edited by scf100; 06-20-2015 at 07:58 AM. |
06-20-2015, 07:55 AM | #15 |
More
1970 2WD Blazer 454 1972 C-10 Extended Cab 350 SBC |
06-21-2015, 10:26 AM | #16 |
That is where i seen it at.
Hoping to get togther on a trade deal.
06-22-2015, 01:05 PM | #17 |
I wouldn't do emblems on a 2wd blazer.
The "K" in the chevy truck lineup indicated 4wd. C10 was 2WD and K10 was 4WD. Since a 4WD Blazer was designated a K5, shouldn't a 2wd have been designated a C5? No such emblem!
72 K5 Blazer - BCHWGN |
06-22-2015, 07:44 PM | #18 |
Never saw it before but looks really clean. 20-30k easy.
72 3/4 ton blazer. 5 inch lift on 35 inch tires. 355 corvette engine with crane roller rockers, rv cam, edelbrock carb and intake with one inch spacer. Thrush Headers with flowmaster 40 duels. 4speed sm465 manual. 4 wheel disk brakes with Inboarded rear shock prerunner style mounts and shocks. |
07-02-2015, 10:32 AM | #19 |
I think i like it smooth too.
07-09-2015, 07:21 PM | #20 |
This what the P.O. Did to mine when he painted it. Simply removed the K5. I actually kinda like it.
--------------------------------------------------------------- Jason. 68’ GMC shortbox https://67-72chevytrucks.com/vboard/...d.php?t=794201 72' 2WD Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=425385 67' LongBox C-10 http://67-72chevytrucks.com/vboard/s...d.php?t=691845 InstaGram ybnorml67 |
07-02-2015, 10:42 PM | #21 |
Well? Were you able to strike a deal on it?
Steven "If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers R.I.P. Oscar R.I.P. Ratchet 1967 Pontiac GTO - Dad was the Original Owner 1970 Chevy 2wd SWB "Oscar's Truck" 1970 Chevy 2wd Blazer "Ratchet's Blazer" 2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar" 2017 Chevy Suburban "BDB" 2020 Chevy Blazer Premier "Foxy" Member of Louisiana Classic Truck Club (LCTC) Shop Build |
07-03-2015, 07:40 AM | #22 |
I still have not been able to meet up with him. We both have had bad schedules the past few weekends.
07-09-2015, 03:30 PM | #23 |
Supposed to meet up on Saturday so we will see how it goes.
07-09-2015, 07:30 PM | #24 |
I still like the K5Blazer fender emblem.
The true truck guys know what it means. And the true 2wd blazer guys understand how rare they are. I just think since it has all the other trim, it needs the fender emblem to complete the truck. The C vs K argument doesn't hold up. Otherwise all the 4x4 trucks would have K10 emblems on their fenders. Ha. (just my opinion that doesn't count)
07-09-2015, 10:30 PM | #25 |
The plain blazer emblem looks ok without the k5 on it. At least no one will Ask If it's A bronco. Lol
