Old 06-19-2015, 02:09 PM   #1
Coursey
Coursey's Avatar
Does anyone know this Blazer?
I was wondering if anyone recognized this Blazer, or know if there was a thread on it?
Coursey is offline   Reply With Quote
Old 06-19-2015, 03:11 PM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: Does anyone know this Blazer?
SUPER NICE blazer.
Never seen it on the board before.
What year is it suppose to be?
(it has 69-70 rear seat and 71-72 front bucket upholstery)
Keith
Convert to disc brakes.
Old 06-19-2015, 03:55 PM   #3
Coursey
Coursey's Avatar
I was told it was a 1970 that was swapped to a 1972.
What is the difference in the rear seat?
Old 06-19-2015, 03:56 PM   #4
Coursey
Coursey's Avatar
I am hoping to trade my biscayne for it. I was hoping that there was a build thread on here somewhere.
The current owner did not build it.
Ay ideas of what it is worth?
Old 06-19-2015, 04:31 PM   #5
lolife99
lolife99's Avatar
The upholstery pattern is different.
(69-70 had the single scroll pattern in the center of each side)
Rear seat looks like an original.
The fronts look re done.
I was going to guess 71-72.
72 door panels and 71-72 gas pedal arm.
I would verify it's not a converted 4x4.
Either way it's super nice!
Keith
Old 06-19-2015, 04:34 PM   #6
lolife99
lolife99's Avatar
I would guess $30k-$40k for an original 2wd blazer.
1970 2wd blazers were 6-lug and 4-wheel DRUM brakes.
So a few things have been changed.
Should have a factory "low hump" floor also.
Keith
Old 06-19-2015, 04:47 PM   #7
Coursey
Coursey's Avatar
The info i have is:
1970 built as a 72
spring yellow
ZZ350 GMPP Crate motor
700r4 Jasper trans.
vintage air
autosound radio
tilt wheel
CPP springs and spindles 4.5/5 no c notch
Disc fronts, drum rear
I have asked for a pic of the SPID.
Old 06-19-2015, 04:56 PM   #8
lolife99
lolife99's Avatar
The "cupholder" console is also a later model item,... but I consider that a plus!
If it was mine,... I would change the wheels and add K5 emblems to the fenders.
Everything else looks very nice, from the pics you have posted.
I would like to see the SPID also,...
Keith
Old 06-19-2015, 07:03 PM   #9
Coursey
Coursey's Avatar
Those wheels are definatly not my favorite. Not sure what i would do, but they would have to go.
I was told that the SPID was removed during the restoration by the PO.
The first 6 of the vin is CE180S
This should be if i am reading it correctly.
4x2
V8
1/2 ton
blazer
1970
St. Louis
This should verify that it is a factory 4x2. Just can not tell what all factory options were installed.
Old 06-19-2015, 10:53 PM   #10
GMC-YA68
GMC-YA68's Avatar
I am opposite. Those wheels are not bad at all for aftermarket. There are lots worse that I have seen. Those are the most "common" I'll say. I would not put any other emblems on it. It's clean without them.
-Keegan-
'72 Jimmy 4x4 - 5.3/4L65E/NP205 swap
http://67-72chevytrucks.com/vboard/s...d.php?t=663780
GMC-YA68 is offline   Reply With Quote
Old 06-20-2015, 07:29 AM   #11
notsolo
notsolo's Avatar
"NEVER SLOW DOWN, NEVER GROW OLD ".. Leave it alone, looks great can't see the wheels while your driving it anyway !
notsolo is offline   Reply With Quote
Old 06-20-2015, 07:52 AM   #12
scf100
scf100's Avatar
Looks like the one I saw at GoodGuys in Nashville last month.....looked really really nice.....
Would you send me a pm with selling price?........that truck had a lot of attention to detail as you can tell from pictures
Value?.........there is 30-40 K in that truck easy......
1970 2WD Blazer 454
1972 C-10 Extended Cab 350 SBC
scf100 is offline   Reply With Quote
Old 06-20-2015, 07:55 AM   #13
scf100
scf100's Avatar
More
1970 2WD Blazer 454
Old 06-21-2015, 10:26 AM   #14
Coursey
Coursey's Avatar
That is where i seen it at.
Hoping to get togther on a trade deal.
Old 06-22-2015, 01:05 PM   #15
bamachem
bamachem's Avatar
I wouldn't do emblems on a 2wd blazer.
The "K" in the chevy truck lineup indicated 4wd. C10 was 2WD and K10 was 4WD. Since a 4WD Blazer was designated a K5, shouldn't a 2wd have been designated a C5? No such emblem!
72 K5 Blazer - BCHWGN
bamachem is offline   Reply With Quote
Old 06-22-2015, 07:44 PM   #16
Chulisohombre
Chulisohombre's Avatar
Never saw it before but looks really clean. 20-30k easy.
72 3/4 ton blazer. 5 inch lift on 35 inch tires. 355 corvette engine with crane roller rockers, rv cam, edelbrock carb and intake with one inch spacer. Thrush Headers with flowmaster 40 duels. 4speed sm465 manual. 4 wheel disk brakes with Inboarded rear shock prerunner style mounts and shocks.
Chulisohombre is offline   Reply With Quote
Old 07-02-2015, 10:32 AM   #17
Coursey
Coursey's Avatar
I think i like it smooth too.
Old 07-02-2015, 10:42 PM   #18
smbrouss70
smbrouss70's Avatar
Well? Were you able to strike a deal on it?
Steven
"If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers
R.I.P. Oscar
R.I.P. Ratchet
1967 Pontiac GTO - Dad was the Original Owner
1970 Chevy 2wd SWB "Oscar's Truck"
1970 Chevy 2wd Blazer "Ratchet's Blazer"
2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar"
2017 Chevy Suburban "BDB"
2020 Chevy Blazer Premier "Foxy"
Shop Build
smbrouss70 is offline   Reply With Quote
Old 07-03-2015, 07:40 AM   #19
Coursey
Coursey's Avatar
I still have not been able to meet up with him. We both have had bad schedules the past few weekends.
Old 07-09-2015, 03:30 PM   #20
Coursey
Coursey's Avatar
Supposed to meet up on Saturday so we will see how it goes.
Old 07-09-2015, 07:21 PM   #21
YBNORML
YBNORML's Avatar
This what the P.O. Did to mine when he painted it. Simply removed the K5. I actually kinda like it.
Jason.
68’ GMC shortbox
72' 2WD Blazer
67' LongBox C-10
InstaGram ybnorml67
Old 07-09-2015, 07:30 PM   #22
lolife99
lolife99's Avatar
I still like the K5Blazer fender emblem.
The true truck guys know what it means.
And the true 2wd blazer guys understand how rare they are.
I just think since it has all the other trim, it needs the fender emblem to complete the truck.
The C vs K argument doesn't hold up.
Otherwise all the 4x4 trucks would have K10 emblems on their fenders. Ha.
(just my opinion that doesn't count)
Keith
Old 07-09-2015, 10:30 PM   #23
Chulisohombre
The plain blazer emblem looks ok without the k5 on it. At least no one will Ask If it's A bronco. Lol
Old 07-09-2015, 11:25 PM   #24
YBNORML
YBNORML's Avatar
WRONG! Happens at least once a year. Drives me crazy!
Jason.
68’ GMC shortbox
72' 2WD Blazer
67' LongBox C-10
InstaGram ybnorml67
Old 07-09-2015, 11:30 PM   #25
Chulisohombre
Haha. Yeah never fails. And they only made the curvy full size bronco 76-78. That's the only one that could be confused with our first gen Blazers.
