08-03-2005, 06:55 PM | #1 |
MY EX DRIVES A BROOM
frame dimension?
does anyone know of the differences between an 82 chevy swb frame and the frame of a 88 k-5 blazer? or know of a website that has this info?
They say nobody's perfect. I'm a nobody, so I must be perfect. Building Nemo -1968 C10 Long Bed FRED -1947 KB-2 International |
08-04-2005, 12:43 AM | #2 |
the k5 is alot shorter i seen a guy put a truck cab on the k5 frame and narrow the bed alot and i got 2 trucks like this at work one is a 2wd the other is a 4x4 but there been out back at work for years ill try and get a side shot for u
http://img.photobucket.com/albums/v5...ropped/sig.jpg |
08-04-2005, 12:06 PM | #3 |
www.73-87chevytrucks.com
LOTS K5 wheelbase is 106.5" a C/K10 wheelbase is 117.5"
This is a SWB C10: This is a '82 K5 2WD: 4x4 will have taller spring perches in back and there will be some in front. The frame rails will be the same though.
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
12-01-2017, 07:11 AM | #4 | |
Collector of Projects
Re: frame dimension?
Can you (or anyone) confirm that the frame and springs are the same and just the perches are different... I am trying to figure out if a FACTORY 2WD Blazer from is the same as a C10... FROM The FRONT perch of the rear springs... Are the holes in the frame in the same location for the front perch? Does anyone have some frame diagrams to compare>>>>> 1978 C10 SWB 1978 K5 Blazer 2WD |
08-04-2005, 04:56 PM | #5 |
the reason i ask is cause i want my blazer to be 2wd and my p/u to be 4x4...just thought that maybe i could swap frames.....guess not. but i can swap suspensions.....hardest part is changing the front to 2wd
12-01-2017, 11:22 AM | #6 |
A pickup frame and a Blazer frame are completely different. Pickup frame is longer and in the rear narraower. The only thing that is the "same" is from the front cab mount forward.
12-01-2017, 11:24 AM | #7 |
See here for dimensions
http://forum.73-87chevytrucks.com/sm...?topic=21682.0
