09-29-2015, 06:31 PM | #1 |
bracket for clutch pedal?
I'm going to swap a t56 into my 72 in place of the auto. What do I need to get a clutch pedal in it? Do I need to replace the bracket that holds the brake pedal with one from a manual truck?
09-29-2015, 07:44 PM | #2 |
Re: bracket for clutch pedal?
You should't have to change out too much cause there never was a big brake pedal for the auto. They were all the same in both types of truck. that is an upgrade I'm doing to mine that are autos, putting in a bigger brake pedal. Jim
09-29-2015, 09:27 PM | #3 |
All about them K’s
All you need is a clutch pedal and linkage or captainfab on the parts board makes some pretty cool hydraulic clutch parts as well. The pedal will slide directly into the auto brake pedal assembly.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne: 5” lift, 35’s, front dana 60 blah blah blah… http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB: 4” lift 33”s… in a million pieces http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 35x12.5x20’s |
09-29-2015, 09:51 PM | #4 |
There is also a rectangular hole on the brake pedal bracket to mount a rubber bumper for the clutch pedal. It's like the bumper for the brake pedal.
11-25-2015, 08:05 PM | #5 |
I'm getting the ball rolling on a tko600 swap in a '71 C10 and am looking for the clutch pedal, linkage and any other goodies I may need.
'71 C10 swb 350sb/700r4 |
11-25-2015, 11:04 PM | #6 | |
The Older Generation
This is an older post but it shows the parts you will need. http://67-72chevytrucks.com/vboard/s...d.php?t=585023 The pedal and shaft will install into your existing assembly.... LockDoc
