08-05-2013, 09:32 PM | #1 |
need a part number or cross reference - a/c accumulator/filter/drier
I finished my ls swap and finally got my '01 truck compressor running and working with my aftermarket a/c unit. And then the compressor dies. Go figure. I have a 5 hr trip coming up Thursday and I desperately need to find a new filter accumulator in town tomorrow. My hoses are configured for a accumulator that has two male insert o ring 3/8 ends. My trinary switch is located elsewhere so that isn't an issue. Since this is an aftermarket unit I haven't found anything in town. Amy ideas what vehicle I can cross reference from? Again:
2 3/8" od 6 1/2" long Two male insert o ring 3/8" fittings Must be in stock. No time to order. Thank you in advance Posted via Mobile Device |
08-05-2013, 10:50 PM | #2 |
Re: need a part number or cross reference - a/c accumulator/filter/drier
Here is a bump ...
A husband can be right...or...A husband can be happy. 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! |
08-05-2013, 11:40 PM | #3 |
08-06-2013, 12:08 AM | #4 |
08-06-2013, 12:40 AM | #5 |
1955 GMC 250 8 Flatbed 1971 C30 157" 350 4spd 10' Flatbed 81 GMC K30 CnC 9' Flatbed 454 T400 89 GMC Jimmy Stock https://67-72chevytrucks.com/vboard/...d.php?t=810958 71 LT1 Convertible, 72 Coupe 69 CJ5, 75 CJ6, 67 M715, 72 M35A2 Bobbed, 95 XLC2 |
08-06-2013, 12:50 AM | #6 | |
08-06-2013, 01:01 AM | #7 |
Just take yours in to NAPA.
Good Luck in your search.
08-06-2013, 01:08 AM | #8 |
This one will work and should be in stock at any Freightliner dealer or truck parts store. Napa may even be able to cross it over for you. The parker/Freightliner part number is A22-14425-002 and it fits Freightliner FLC and FLD series trucks. The switch port has a Schrader valve in it so you don't have to worry about it leaking.
My build thread. |
08-06-2013, 07:00 AM | #9 |
Old member
From what I have learned you don't need the dryer [sightglass] if you are running the acumalator in the system. If you have swapped over to 134-A you really don't need it because it want take as much 134-A as it did R-12 so it's always going to have bubbles in it when watching it. So if u fill it up to the point of no bubbles it's over filled and the AC want work as good and can cause compressor failure.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
08-06-2013, 07:38 AM | #10 |
I thought I have read that you can't use the stock compressors because of the variable ratio guts? That they would last a while and then die. Thought you had to use an aftermarket compressor on an LS conversion?
'83 K20-TPI '73 C10 '79 C10-ex-diesel(SOLD) '07 Tahoe(Son driving) '14 Suburban-DD '71 C10-current project |
08-06-2013, 08:04 AM | #11 | |
Driers are used with expansion valves because they want bubble free liquid refrigerant so a drier is placed on the high side. Orifice tubes don't care about bubbles but need an accumulator on the low side to prevent liquid from getting to the compressor. I think the LS truck compressors are fixed displacement.
08-06-2013, 11:47 AM | #12 |
08-06-2013, 12:24 PM | #13 |
http://www.napaonline.com/Catalog/Ca...118_0333709307
TWD MEI7118 /C Filter Dryer Fitting Type[s] : O-Ring A/C Filter Dryer Inlet Fitting : #6 (3/8") Male O-Ring A/C Filter Dryer Length : 8" A/C Filter Dryer O.D. : 2-1/2" A/C Filter Dryer Outlet Fitting : #6 (3/8") Male O-Ring A/C Low Pressure Switch Thread Size : None Compatible Refrigerant Type : R12 / R134a
08-06-2013, 01:37 PM | #14 |
member #16
I'm confused. Do you need an accumulator? (low side) or
filter dryer receiver? ( high side). You say you need an accumulator but show pics of dryers. Andy4639 shows an accumulator in his pic.
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors http://www.flickr.com/photos/1745471...7602865984234/ |
08-06-2013, 02:04 PM | #15 | |
Old member
I bought a new compresssor because the old A-6 never worked well with the cycling the system and 134-A freon + a new condensor for expansion also.
