Old 06-22-2010, 01:15 AM   #1
IAFF2407
IAFF2407's Avatar
roof rack installation
does anyone have experience installing a roof rack. Question is; does the "screw plug" install from the top down, or from the inside of the cab to out. sorry for the bad pics. the brass screw inside is flush with the base of the "non flange" end. My thought process is from the top in, when you screw down the rack "legs" the brass plug will "bunch up" the rubber like a gyproc wall plug. The instructions pic suggests differently.
thx,
Al.
1972 GMC Sierra
1972 GMC Super Custom Suburban
IAFF2407 is offline   Reply With Quote
Old 06-22-2010, 10:02 PM   #2
Hart_Rod
Hart_Rod's Avatar
Re: roof rack installation
thx,
Al.
You are most correct, oh wise one!
Hart_Rod is offline   Reply With Quote
Old 06-23-2010, 12:52 AM   #3
IAFF2407
IAFF2407's Avatar
LOL, kinda figured you would be the one to reply sooner or later. thx. I also found out the the package was missing 5 screws that go through the legs in the rubber plugs. Do you know where to find these? 1 1/4 x 1/4 coarse thread. small ovaled head.
thx again,
Al.
1972 GMC Sierra
Old 06-23-2010, 10:46 AM   #4
Hart_Rod
Hart_Rod's Avatar
thx again,
Al.
, I was able to pick some stainless ones up at a hardware store. Let me know if you can't find them.
R/
Old 07-02-2010, 02:00 AM   #5
DBear
DBear's Avatar
can you explain in dummy english just how these racks mount on top of the burb. I have one that I need to install. what are those "plugs" you have in the pics????
DBear is offline   Reply With Quote
Old 07-08-2010, 09:53 AM   #6
Frizzle Fry
Frizzle Fry's Avatar
The "plugs" are more commonly known as well-nuts. They go through about a 1/2" hole in the roof and have a threaded brass insert at the bottom for a 1/4-20 screw. When you tighten it down it collapses the well-nut tight around the sheet metal providing a seal and an anchor.
Frizzle Fry is offline   Reply With Quote
Old 01-15-2011, 12:47 AM   #7
johnsons63
how much is a roof rack? im planning to install a roof rack this week before we go on vacation this coming weekend... thanks
_______________________
OEM Bed rails, OEM Brush guard, Magnaflow 22" with Gibson pipes, PRG Mini-lift, Cooper Discoverer S/T 35x12.50x17, Lund hood protector, Go Rhino, Ventshade in-channel window visors, Bushwacker Extenda-flares, front window tint.
johnsons63 is offline   Reply With Quote
Old 01-15-2011, 03:33 AM   #8
ole red
The roof racks for the 67-72 with the stainless strips are hard to come by. And i have found that the bolts at the hardware store are a little different but will work. I was wanting to know who manifactured these racks?
69 stepside, 1/2ton, 4X4, 350/350/205
ole red is offline   Reply With Quote
Old 01-21-2011, 04:15 AM   #9
71gmcburb
71gmcburb's Avatar
I'd like to get 1 also
a wise man once said "There are only two real rules to life...
1 - Don't sweat the small stuff
2 - Everything is small stuff
71gmcburb is offline   Reply With Quote
