Old 06-03-2007, 12:26 PM   #1
72BLAZERDUDE
72BLAZERDUDE's Avatar
Push-Loc fittings
I started putting airline on my Blazer and I am using push-loc fittings. Do these things really go together as easy as mine did. Just seems like they went together way to easy. I have never used these before and did not know what to expect.
72 2wd 307/AT/AC/TILT WHEEL
78 JIMMY HIGH SIERRA
72BLAZERDUDE is offline   Reply With Quote
Old 06-03-2007, 12:38 PM   #2
jeffspower
Well, Whoop-dee-do!
jeffspower's Avatar
Re: Push-Loc fittings
Yep, nothing to it. Be sure to give the lines a tug to seat the locks, or they can blow out.
'68 GMC shortbox 4x4 350/SM465/T221- bought it in '83 SOLD
'72 K20 500 Cad/TH400/NP205 SOLD
'92 Chevy 2500 6.5 mech TD 4L80E crusty daily driver
'72 Monte Carlo... sweet low mile toy
'11 Dodge Challenger IE 392 6spd... midlife car
jeffspower is offline   Reply With Quote
Old 06-03-2007, 03:29 PM   #3
smashingchuck
It'd be alot cooler if you did
smashingchuck's Avatar
yep the PTC's are a snap - nothing to it. Just make sure the line is going straight in - it will leak otherwise.
78 Build Thread
4Runner Build
smashingchuck is offline   Reply With Quote
Old 06-03-2007, 04:32 PM   #4
SCOTI
SCOTI's Avatar
Make sure the air-line has a clean, 90° cut on the end before installing to the PTC fitting. This helps reduce the chance for leaks & 'blowing-out' of the fitting.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
SCOTI is online now   Reply With Quote
Old 06-12-2007, 08:06 PM   #5
pissonNOS
senior member
pissonNOS's Avatar
mine arent 100% straight they have a bit of a bend is there any give with them or not?
69 GMC bagged
pissonNOS is offline   Reply With Quote
Old 06-12-2007, 07:26 PM   #6
randomhero472
randomhero472's Avatar
I've been told you can get these @ lowes/home depot.. went to look this weekend and they have them, but they're a PVC-plastic material, no metal.. however the plastic fittings are rated @170 psi.. where is the best place to buy these fittings, would a semi-truck shop have 1/2" and 3/8" fittings?
67' in the "build" process.. soon to be bagged, big wheels ect, finally got it back home!!
randomhero472 is offline   Reply With Quote
Old 06-12-2007, 07:45 PM   #7
dwcsr
Hollister Road Co.
dwcsr's Avatar
170 is way to low. use brass ones.
http://www.hoseandfittings.com/ or
http://www.fittingsandadapters.com/index.html
both have good pricing
Old 06-13-2007, 11:40 AM   #8
jimmydean
jimmydean's Avatar
I had 1 tee that leaked because the lines weren't straight. I just used some well places zip ties so the line was secured before the fitting and it was fine after that.
New Project: 1966 LWB C20
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
http://67-72chevytrucks.com/vboard/s....php?p=4295210
jimmydean is offline   Reply With Quote
