04-03-2009, 05:14 PM | #1 |
Request for RECOMMENDATION on needed size of bottle jack
Due to a misunderstanding about the intent of my previous post, I am reposting this question.
My '72 Chevy C10 did not come with a jack for changing tires, etc. I intend to acquire from a store a new generic bottle jack to carry in the truck, to replace what originally came with my truck but is no longer with it. What I am looking for is a recommendation on the size of bottle jack I need. I am not asking anyone to provide me a jack, and I am not asking where I could acquire an OEM jack. I would simply like to know, in the experience of people on this forum, how big of a bottle jack do I need? I'm primarily concerned about needed lift height, so that I can get a front or rear wheel off the ground to change a tire using the recommended jack points. My suspension is stock, with no fancy wheels or large tires. |
04-03-2009, 05:46 PM | #2 |
Re: Request for RECOMMENDATION on needed size of bottle jack
Good topic for those of us who have no jacks...
A husband can be right...or...A husband can be happy. 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! Last edited by 70cst; 04-04-2009 at 09:47 AM. Reason: Correcting response |
04-03-2009, 05:59 PM | #3 |
let the air out of a tire and measure how much clearance you have on what you want to jackup thats the size you'll need in an emergancy flat tire situation
04-03-2009, 06:15 PM | #4 |
70cst,
Sorry for duplicating your post. I wasn't expecting you would repost my initial request, so I started this new very carefully phrased post. Are all newbies this much of a hassle, or am I uniquely annoying? |
04-03-2009, 08:42 PM | #5 | |
depends on your tire size, axle height from ground + 2" i'd say... I have an original that I can measure if you want to know how high they go... Or just get one of those little one's from the store that has a corkscrew top..
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
04-03-2009, 09:35 PM | #6 |
I have a 1.5 ton bottle jack that works.It has the screw out part in the cylinder shaft that extends about 5".
Also, have you tried the factory screw jack from a 73/87 Chevy truck? I have used the bottle jack on my 68,but not the screw jack. Stupid truck had the original tires on it when I bought it and one had the audacity to go flat on me!Seems nothing lasts very long anymore! Mike. |
04-03-2009, 06:46 PM | #7 |
He's got mean nasty FANGS!
Looks like a moderator should slack up a little bit instead of editing QUESTION'S as WTB.
Your old post has been restored and corrected.
2004 K2500 Burb 1999 C3500 1985 Cutlass Supreme 1969 C-10 1967 C-10 Panel josh@67-72chevytrucks.com |
04-03-2009, 07:40 PM | #8 |
gregorydh my apologies...I guess I need to learn how to interpret the way the phrase "Want to buy" is applied. I took it one way and it is apparent that way of interpretation was the wrong way. My mistake.
A husband can be right...or...A husband can be happy. 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! Last edited by 70cst; 04-03-2009 at 08:08 PM. |
04-03-2009, 08:21 PM | #9 |
HI I have a bottlejack out of a landrover. it is short and extends purty high
04-03-2009, 10:25 PM | #10 |
I usually use a 1.5 ton bottle jack too. Plus a short 2 X 4 10-12 " for use in the mud seems thats wear I usually end up jacking stuff.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL" "You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig." ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629" |
04-04-2009, 09:33 AM | #11 |
454 MAKES IT ROAR
Just bought a new Bottle Jack for this very same reason, it's a 4T but very small fully extended the whole thing measures 13-1/2 inches. I think thats more than enough to get ground clearence on an inflated tire.
Nigel. An American living in a British body. 1971 Chevy Cheyenne 10 454 "In a time of universal deceit, telling the truth becomes a revolutionary act." - George Orwell "When injustice becomes law, resistance becomes duty" - Thomas Jefferson No more pain. 03.12.60 -- 12.28.10 http://www.youtube.com/Eightbanger |
04-04-2009, 04:01 PM | #12 |
Currently Blazerless
I bought a Suburban years ago and in it was a bumper jack that was hydraulic, it breaks down and works very well on these years of trucks. I believe it is period correct and was distributed by Hickey.
1972 C/30 133" W.B. C&C 1970 GMC 3500 157" W.B. single wheel C&C |
04-04-2009, 04:25 PM | #13 |
20' Daredevil (Ret)
I'd recommend a 3 ton, b/c I like a little extra (in fact, that's what I have). The screw extension helps, and you can always throw in a sturdy block of wood if needed -- but never use a concrete or cinder block.
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay |
04-04-2009, 06:46 PM | #14 |
It seems like most of them would not have enough stroke to lift it high enough to get the spare on. I'm surprise some have had luck with these. The other problem I would see is that they aren't very stable with the small pad. In a parking lot it might be ok, but if you were on the side of the road it might be dangerous.
No more dragtruck for me. I'm building a new ride though. It's a '71 fleetside, 400 sbc, 700R4. Working on it now, finally. Soon to have Edelbrock Pro Flo EFI, Vintage Air, 1 piece windows, buddy buckets, etc. My new build thread: http://67-72chevytrucks.com/vboard/s...17#post2861817 Best pass with the old dragtruck: 5.32 @ 131.6 mph 1/8 mile w/ a 1.25 60' Fogger/Plate 2003 Best pass with the street 406 hydraulic roller motor w/ mild plate tuneup 5.93 @ 114 mph 1/8 mile w/ a 1.29 60' 2003 or 2004 |
04-04-2009, 09:09 PM | #15 |
Eat My Rust
I have the little bottle jack that came with the truck. Not sure how low it can go, but it can lift high enough to get a 30" tire clear off the ground. Though I may need a new one, it's gear inside is skipping as I lift up.
04-04-2009, 10:37 PM | #16 |
Bottle jacks are rated by weight/tonnage.Just go by what the vehicle weighs and allow for loads.
Any jack will raise the vehicle enough to remove the tire/wheel.Set it on a wood block if it`s too short.
04-05-2009, 12:33 AM | #17 |
where can you buy bottle jacks?
04-05-2009, 12:38 AM | #18 |
20' Daredevil (Ret)
Just about any auto parts store, or Wally World, or Harbor Freight, or Sears, or....
