10-06-2013, 09:43 AM | #1 |
Question for Keith Seymore or Anybody that knows.
Still looking for an answer on what finish the leaf springs came from
the factory. Where they painted from the factory or just had the natural finish? Where they different from plant to plant? Most of the other discussion boards for other Chevy products indicate they where natural finish. (Dull gray; almost black) Anybody have a picture of one? Thanks in advance--Larry |
10-06-2013, 06:21 PM | #2 |
Re: Question for Keith Seymore or Anybody that knows.
It could vary from plant to plant ....and from year to year....but the originals I have were not painted or coated.
Usually they will be lightly rust colored ...even on dry climate or garaged trucks. |
10-06-2013, 08:22 PM | #3 |
My 73,76, and 83 C20s - none were painted. I did recently paint my current 83 springs after sanding off the surface rust - just for appearance.
10-06-2013, 09:49 PM | #4 |
I seem to recall they were a light grey (perhaps raw spring steel or maybe painted with a light primer).
They may have also received a little overspray while shooting the rear diff and brake drums with chassis black immediately prior to body drop. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
10-07-2013, 08:20 AM | #5 |
Thanks to all you guys for some input. Plan on powder painting them to
as close as I can get to the proper color. BTW; the bushings for these late 70 Chevy 1/2 ton (2WD) is GM part number 468481 which is dicontinued now but your Chevy dealer can run a search and find some NOS ones at various Chevy dealers which is what I did. Found them pretty easy.FYI Larry |
10-08-2013, 05:22 AM | #6 |
Best bet may be some epoxy primer, or some semi-gloss chassis paint.
1987 2 ton 1982 250/TH350 beater in progress Dad's 1981 3/4 L6 3 on tree posi and no options, awaiting restoration or scrapping Plus a mess o' tractors |
10-08-2013, 07:56 AM | #7 |
The springs that I bought a couple of years ago (that the spring shop said were on the shelf for about twenty years) were natural finish with a clearcoat on them.
10-08-2013, 08:09 AM | #8 | |
that are light gray and some dark gray (almost black). Thanks-Larry |
10-08-2013, 01:26 PM | #9 |
Almost black..I think. I'll check tonight.
10-09-2013, 10:02 AM | #10 |
Dark,dark gray with a yellowed looking clearcoat.
10-09-2013, 03:35 PM | #11 |
Rich84: Thanks for the response. I think I'm going with the dark dark
gray like you and others have indicated. Will check with my Powder Painter to see how close he can get. Thinking a color very similar to some exhaust manifolds we see. Larry |
