Old 06-08-2015, 02:11 PM   #1
Tilt
Is the NSS wire absolutely necessary
Buttoning up some loose ends and was wondering if this wire is necessary for the engine to run. Motor/computer are 2004 LQ9 dbw, trans is a 2005 4L80, harness is a BP Automotive Premium harness, and the truck is an '86. The switch on the bottom of the column only has the plug for the back up lights. The truck was originally a 3 speed on the column, so I believe it had a switch on the clutch pedal that only allowed it to start if the pedal was pressed down.
'83 Silverado Step Side
'85 GMC short bed.
'86 Chevy Step Side Custom Deluxe
LQ9/4L80 swap (SOLD)
Tilt is offline   Reply With Quote
Old 06-08-2015, 08:01 PM   #2
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: Is the NSS wire absolutely necessary
I don't have an NSS at all. I think my shifter has one, but I never bothered to hook it up (but I'm on auto). On a manual, its a good idea just for idiot proofing...but its not physically required for the truck to start (boats don't have NSS for example)
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 06-08-2015, 08:42 PM   #3
ls1nova71
ls1nova71's Avatar
Ever seen somebody reach in the window and start their car while its in gear? I have, and its not pretty...... That said,, some columns have a physical lock out in any gear but neural and park, meaning they wont turn to the crank position in drive, I was thinking an 86 would be that way.See if it will turn in gear, if not you shouldnt need it.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 06-09-2015, 06:05 AM   #4
Tilt
Thanks guys, I'll check it when I get home this evening.
'85 GMC short bed.
