02-25-2014, 06:25 AM | #1 |
64 Chevy with 350 Small Block Fan Question
Wondering what do you guys recommend for a great cooling fan on my truck. The issue I have now is that if I am stuck in traffic for like 5 minutes( pray not more) and the outside temp does not matter. My gauge goes almost to the end but as soon as I am moving its back to the 190 to 200 degree mark..
Wondering what is recommended as summer time is coming and I am in a very hot climate???? Thanks in advance |
02-25-2014, 07:30 AM | #2 |
Re: 64 Chevy with 350 Small Block Fan Question
What do you have in it now for fan and shroud? What is in the truck for engine and radiator? May be able to give better answers.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
02-25-2014, 07:39 AM | #3 |
Engine is 350 small block at it has Fan and Shroud but I bought the truck last year and not sure what type Radiator or Fan. Wish I had more info.
02-25-2014, 07:44 AM | #4 |
I'm running a factory replacement copper rad, and a clutch fan from LMC. stays at 180 at the time in summer.
past trucks: 1980 C-10 Silverado SWB 1961 C-10 custom cab LWB 1966 C-10 custom cab LWB |
02-26-2014, 12:26 PM | #5 |
The factory clutch fans are awesome. I test fitted the factory clutch fan assembly from my 1969 Chevelle with 350 into my 64 C10 and it fit fine, so I ordered another 69 Chevelle clutch fan setup for the truck. It's been cooling the 350 in my C10 great for many years.
02-25-2014, 07:43 AM | #6 |
I put a 16 inch electric fan in my truck and never overheat. I have driven it in show traffic at the GG's when it was 105 outside and it ran 190.
02-26-2014, 12:33 PM | #7 |
Also...what kind of gauge? Is it factory or aftermarket?
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
02-26-2014, 03:07 PM | #8 |
02-26-2014, 03:51 PM | #9 |
I think the 5 blade flex fan on mine is 15" and has about a 1/2" gap between it and the shroud. 13 seems a little small. Can you post a pic of your setup?
Jimmy
02-26-2014, 09:39 PM | #10 |
If its heating up that quick either partially stuck thermostat, or no thermostat, plugged radiator, to small a radiator, you really need to confirm all of the above....are you using antifreeze, good rad cap, radiator holding pressure...?
`64 C10 vortec 350/350/373 posi `69 RS/SS 350/350/308 `37 Ford 406/350/324 traclock `68 Dart 370/904/323 suregrip |
