Old 02-25-2014, 06:25 AM   #1
jolobo64
64 Chevy with 350 Small Block Fan Question
Wondering what do you guys recommend for a great cooling fan on my truck. The issue I have now is that if I am stuck in traffic for like 5 minutes( pray not more) and the outside temp does not matter. My gauge goes almost to the end but as soon as I am moving its back to the 190 to 200 degree mark..
Wondering what is recommended as summer time is coming and I am in a very hot climate????
Thanks in advance
jolobo64 is offline   Reply With Quote
Old 02-25-2014, 07:30 AM   #2
PGSigns
PGSigns's Avatar
Re: 64 Chevy with 350 Small Block Fan Question
What do you have in it now for fan and shroud? What is in the truck for engine and radiator? May be able to give better answers.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 02-25-2014, 07:39 AM   #3
jolobo64
Engine is 350 small block at it has Fan and Shroud but I bought the truck last year and not sure what type Radiator or Fan. Wish I had more info.
Old 02-25-2014, 07:43 AM   #4
Indian113
Indian113's Avatar
I put a 16 inch electric fan in my truck and never overheat. I have driven it in show traffic at the GG's when it was 105 outside and it ran 190.
Indian113 is offline   Reply With Quote
Old 02-25-2014, 07:44 AM   #5
bonehead
bonehead's Avatar
I'm running a factory replacement copper rad, and a clutch fan from LMC. stays at 180 at the time in summer.
past trucks:
1980 C-10 Silverado SWB
1961 C-10 custom cab LWB
1966 C-10 custom cab LWB
bonehead is offline   Reply With Quote
Old 02-26-2014, 12:26 PM   #6
MikeN
MikeN's Avatar
The factory clutch fans are awesome. I test fitted the factory clutch fan assembly from my 1969 Chevelle with 350 into my 64 C10 and it fit fine, so I ordered another 69 Chevelle clutch fan setup for the truck. It's been cooling the 350 in my C10 great for many years.
MikeN is offline   Reply With Quote
Old 02-26-2014, 12:33 PM   #7
1963c-10
1963c-10's Avatar
Also...what kind of gauge? Is it factory or aftermarket?
1964 Short bed trailer
Old 02-26-2014, 03:07 PM   #8
jolobo64
It is aftermarket like sunpro. I measured the fan and it is a 13" fan and the shroud measures 26.5 x 16 and the core of radiator measures 23.5 x 15.5.
Old 02-26-2014, 03:51 PM   #9
PGSigns
PGSigns's Avatar
I think the 5 blade flex fan on mine is 15" and has about a 1/2" gap between it and the shroud. 13 seems a little small. Can you post a pic of your setup?
Jimmy
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
Old 02-26-2014, 09:39 PM   #10
Rich 5150 69
Rich 5150 69's Avatar
If its heating up that quick either partially stuck thermostat, or no thermostat, plugged radiator, to small a radiator, you really need to confirm all of the above....are you using antifreeze, good rad cap, radiator holding pressure...?
`64 C10 vortec 350/350/373 posi
`69 RS/SS 350/350/308
`37 Ford 406/350/324 traclock
`68 Dart 370/904/323 suregrip
Rich 5150 69 is offline   Reply With Quote
