Old 07-25-2004, 10:21 PM   #1
A.P.
Black 72 Chevy
A.P.'s Avatar
Carb change from Q to Edelbrock
Hi guys and gals.
I want to replace my Q jet carb with an Edelbrock 1406 carb that I bought from the net. I'm also going to replace the stock intake with an edelbrock torker 2. My question is, where do you connect the distributor vacuum advance. The Q carb has the connection next to the choke but the edelbrock carb has none. Check the pics. Pics did not show, will have to resize.
A.P.
A.P. is offline   Reply With Quote
Old 07-25-2004, 10:31 PM   #2
72C203503ONTHETREE
72C203503ONTHETREE's Avatar
There should be a few small vacuum ports on the front of the carb near the idle mixture screws. Check for a line that has vacuum above idle speed, that is your vacuum advance port.
72 Chevy C20, SOLD (Dang it.)
09 Challanger RT six speed in all black.
74 Datsun 710 wagon, all 1.8 liters of screaming Datsun power.
73 C10 long bed, 350/350 combo, nice shape.
72C203503ONTHETREE is offline   Reply With Quote
Old 07-25-2004, 11:02 PM   #3
A.P.
Black 72 Chevy
A.P.'s Avatar
72C203503ONTHETREE
Thanks for your help. I Will check as soon as I install it.
A.P.
Old 07-25-2004, 11:11 PM   #4
orange72
orange72's Avatar
yea it should be the left port.
1972 chevy long bed. Currently under construction!! Bagged, 383/700r4.
orange72 is offline   Reply With Quote
Old 07-25-2004, 11:23 PM   #5
shuttermutt
Don't say "Oops!", Doctor
shuttermutt's Avatar
One thing that might help is to hit the Edelbrock web site. They've got PDF versions of the 1406 installation manual and the 1406 rebuild manual. They helped me a bunch when I rebuilt my 1406 and installed it a few weeks ago. Good luck with that carb!
'Mutt
1968 CST LWB: R.I.P.
1967 Chevelle: TPI 454 beast
1967 C10 SWB: Claimed when Bumpster didn't put it on his list
shuttermutt is offline   Reply With Quote
Old 07-26-2004, 01:50 AM   #6
neonlarry
neonlarry's Avatar
If you engine is stock, I would use a different intake manifold. The torker 2 is a single plane, not real great for a stock engine. If you have an engine that needs it though, then hey, sounds good to me.
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights
99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs
95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI
neonlarry is offline   Reply With Quote
Old 07-26-2004, 04:22 AM   #7
A.P.
Black 72 Chevy
A.P.'s Avatar
Thank you all. I do have a stock engine and according to the Edelbrock web site the torker 2 intake is for high-performance. Well, I haven't taken the stock intake off the engine. I will just replace the carbs.
A.P.
Old 07-26-2004, 05:57 AM   #8
GMC AMI
GMC AMI's Avatar
A stock motor would still gain in horsepower and torque with single plane. It is meant
for wide open throttle gain.Still the weight reduction alone would prompt me to change
from the stock cast iron. This intake for sure is what racers want. A dual plane would be better in your case. Good luck however you proceed.
1968 Chevy 4x4 307 4 speed
GMC AMI is offline   Reply With Quote
Old 07-26-2004, 07:14 AM   #9
shuttermutt
I think the point that some folks are trying to make is that you'll need to get either an adapter or a new intake when performing the swap. The Q-Jet is spread bore whereas the Edelbrock is square bore. Adapters will work or you can do what many folks do (including myself) and replace the intake while you're at it.
'Mutt
Old 07-26-2004, 10:36 AM   #10
72C203503ONTHETREE
The edelbrock has two sets of holes so you can install it on either a Holley style intake or a Q jet intake. The Torquer intake is not that great, the Victor Jr. is actually better since you get a lot of top end but dont lose much bottom end, the standard ports arent that big so it doesnt lose very much velocity. It can be ported quite a bit to use better heads and cams though. The Performer RPM and RPM Air Gap would be the best compromise though. I am using a RPM with a 600 cfm Carter and a 1105 Summit cam kit on my 350 that is otherwise stock except for roller rockers and stud girdles. It works well even if its in a 3/4 ton truck with a three on the tree.
Old 07-26-2004, 02:36 PM   #11
shuttermutt
It never even dawned on me that's what those holes were for. I always just assumed you had to run an adapter. Huh, I guess you really can learn something new every day.
'Mutt
Old 07-26-2004, 06:08 PM   #12
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
I just used the Performer intake, with my 1405. Later, changed to the Edelbrock Q-Jet. No complaints.
Member Nr. 2770
Old 07-26-2004, 12:37 PM   #13
2wdBlazer
The Blazer King
2wdBlazer's Avatar
I asked the same question the other day in the Engine Forum.
http://67-72chevytrucks.com/vboard/s....php3?t=112705
I used the Drivers side port and it seems to work very well.
72 2wd Blazer. Its the superbichinest, megacoolinest, superflowinest.
2wdBlazer is offline   Reply With Quote
