Old 10-09-2004, 01:01 PM   #1
c10crazy
Like a Rock!
c10crazy's Avatar
Question Removing wipers?
What is the trick to remove the wiper arms?
69 LWB
Runs great - work in progress
Mess with me and you mess with the whole trailer park!
c10crazy is offline   Reply With Quote
Old 10-09-2004, 01:03 PM   #2
Joe67
67 is sold
At the base of the arm, there is a clip you need to press in to slide it off the shaft.
Joe - Formerly 67c10step
1967 Chevy Stepside - ECE 4/6, fuelcell, 5lug - SOLD
gr8lakes - My ebay auctions
Click here to order forum apparel :: Click here to become a subscribing member
Joe67 is offline   Reply With Quote
Old 10-09-2004, 01:34 PM   #3
c10crazy
Like a Rock!
c10crazy's Avatar
Do you lift up the arm first, then press toward the cowl?
69 LWB
Old 10-09-2004, 01:52 PM   #4
kw
kw's Avatar
Wipers
Haven't done it in a while, but I used to just depress the clip, then get a rag, fold it over several times and place it underneath the wiper. Get a screwdriver and lever it between cowl (on rag pad of course) and gently pry upward and wiper assembly should come right off.
kw is offline   Reply With Quote
Old 10-09-2004, 03:56 PM   #5
ChevyDude
What Kw said should work just fine. Sometimes you have to move the screwdriver around a bit and pry from different places.
Alex
1971 Lil' Red 350 SBC 700R4
ChevyDude is offline   Reply With Quote
Old 10-09-2004, 06:01 PM   #6
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
I have a tool that I bought from NAPA that is for removing wiper arms. It goes beneath the arm, at the cowl, and you squeeze the handles together to lift it off. Seems like it's a K-D tool......in case the other ideas don't work for you.
Member Nr. 2770
Old 10-09-2004, 07:44 AM   #7
MOTHERTRUCKERS
We use a rag on the cowl and a claw hammer, the nail pulling end and if it still won't come off we turn the hammer around and vent some frustrations.
Rest in Peace Ed. Thanks for all the good times.
MOTHERTRUCKERS is offline   Reply With Quote
Old 10-10-2004, 09:42 PM   #8
purple gas
a hammer works , but I've found a small flat Pry bar, like a finishing carpenter would use works great.. specially if you slip, less chance of smashing your glass. it's about a 90 degree angle, and easier to control than a claw hammer
purple gas is offline   Reply With Quote
