Blue 67
![]() Join Date: Apr 2004
Very High RPM at start
Today I went to start the truck after few days. Last time I started it was the time that I reset the timming with some of board memeber help.At that time, it was startind and idling nicely. Since then truck was parked in the Garage. Is my timming too advance? Any help would be appreciated. Thanks
Geared for Collision
prob just the choke kicking in did you try kicking it down? as long as was idling and running good before and you tightened distributor down tight it shouldnt be the timing. check your choke adjustments and if doesnt kick down once warmed up then adjust the idle. how high is very high rpm when starting? if roaring then look and see whats makeing the throttle move when you start it. and dont run it like that till you get figured out. what kind of carb you got?
MEMBER OF THE 4 WHEEL DISK BRAKE CLUB 1970 C/K20 3/4 Ton 1996 Collectors Edition Corvette 1977 Corvette Coupe Last edited by Budweis; 10-30-2004 at 12:38 PM. |
Blue 67
Carb is new edlebrock 1406 with electric choke, and yes it roars right at start. I tightend the distributor. I didn't connected the chock since I am in LA/Ca and it's choke was not connected before either. I am just afraid to let it run like this until it warms up.
Thats the Hillbilly way
Check to see if the High speed idle cam on the carb is stuck .Here is a PIc you can back the screw off the cam .
BILL Torrance Calif 90504 Member DUF Club Member Old Farts Club 72 3/4ton Custom Camper BB402/400 trans Dynomax Cerama-coat headers , Hei distributor ,Edelbrock 1411 air,ps,pb,leafsprings ,98 chevy 60/40 seat,S10 shoulder belts tilt,3.54 Dana 60 rear. 16" Eagle wheels with LT265/75 16 tires,Gaylord Lid,H4 headlights with 100W relay conversion. " If I knew I was going to live this long I would have taken better care of myself " Marriage changes passion...suddenly you're in bed with a relative. A GUY'S PRAYER.... Lord, I pray for a nympho with huge boobs who owns a liquor store and likes to fish and hunt and has a Harley .Amen , Last edited by Bill72BB; 10-30-2004 at 01:40 PM. |
Blue 67
Thanks Bill72. It was stuck and I don't know why. I thought I had a good linkage but apparently when I try to tighten the linkage it doesn't move freely. Anybody knows if there is any kind of throttle linkage which I need to use for edlebrock?
#6 | |
If you don't want to run the electric choke just back the screw off so it never hits the high idle cam.
BILL Torrance Calif 90504 Member DUF Club Member Old Farts Club 72 3/4ton Custom Camper BB402/400 trans Dynomax Cerama-coat headers , Hei distributor ,Edelbrock 1411 air,ps,pb,leafsprings ,98 chevy 60/40 seat,S10 shoulder belts tilt,3.54 Dana 60 rear. 16" Eagle wheels with LT265/75 16 tires,Gaylord Lid,H4 headlights with 100W relay conversion. " If I knew I was going to live this long I would have taken better care of myself " Marriage changes passion...suddenly you're in bed with a relative. A GUY'S PRAYER.... Lord, I pray for a nympho with huge boobs who owns a liquor store and likes to fish and hunt and has a Harley .Amen , |
Watch out for your cornhole !
![]() Join Date: Jun 2003
You need to hook the choke wire up. That wire is what heats the choke element to open it up when the truck gets warmed up.
I think if he isn't going to hook up the choke wire, Then take the choke off completely. Otherwise when it is real warm outside the choke will be open and the idle will be off again. The choke is 1 wire hook up and set it once and forget it, If the temp is always warm out the choke will never cause the choke to close, If the temp drops the choke will give him a little faster idle. To adjust the choke so it never closes I think he just has to loosen 3 small screws then turn the choke till it opens. This should be done cold.
72 longhorn c30 502BB/th400/fact air/4.11rear/ custom camper 72 bug(the better half's) under reconstruction 2009 HHR aqua blue 71 GMC k20 350/sm465 2009 Chevy hd3500 6.6 Victory Red crew cab dually Dave & Jeanne |
Setting an electric choke needs to be done with the engine at operating temp. Loosen the three screws, turn the choke housing clockwise until the butterfly starts to close, then back off one notch.
Fawker Fab three seater rock crawler buggy 498 BBC/SM465/203/205 doubler, propane, 5.13's, 42" PB Rockers '66 C10 - The new hot rod '77 3+3 Dually - 12 valve 4wd conversion tow rig project '28 Ford 2 door sedan street rod RevLimit Offroad "Hang on beer, we can do this." |
