Old 12-22-2004, 08:27 PM   #1
special70gmc
special70gmc's Avatar
trak lok possi
ok i instaled the trak lok in my dana 60 a couple of months ago and was wondering why it doesnt always lock? if im turning left it will always lock but in a streight like altot of the time i jut get right tire smoke show off the line. i need the tracktion badly and dont know why it does this. kinda aggrivating being imbarised when ur truck lites up one tire instead of two for a half mile thanks alot -kyle i need this---->
1986 c-10 swb 5/7 drop 20'' coys
1958 belair 2door
special70gmc is offline   Reply With Quote
Old 12-22-2004, 08:37 PM   #2
724wdcopper
graphic designer
724wdcopper's Avatar
always hooks going left, huh? you must have gotten the NASCAR model
724wdcopper is offline   Reply With Quote
Old 12-22-2004, 08:41 PM   #3
Brainchild
Still drivin' a Rat Rod
Brainchild's Avatar
Did you replace the clutches in the posi unit?
Rusty Member #13872
Instead of saying.....you are a discomfort in the back of my front.....one should be able to say...... you are a pain in the *a$#*
71 GMC LWB
49 Chevy
85 Chevy G20
Check out my website
Brainchild is offline   Reply With Quote
Old 12-22-2004, 09:00 PM   #4
Rod
Did you add the GM posi-lube..you need that too.
Senior active founding member.
70 3/4 ton GMC Suburban 4x4 250/4 spd.
71 1/2 ton Suburban Chevy 4x4, 350/350
72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane
2005 FLSTSCI Harley Springer
85 FXSB Harley Lowrider
72 Triumph 650 Bonneville 5spd
"Poor people don't have hobbies" Quote from wife.
Rod is offline   Reply With Quote
Old 12-22-2004, 11:24 PM   #5
special70gmc
its a brand new unit, and no i didnt add the lube ill get a bottle of that, is there any other reason it would be so lame at locking? is it cuz of the motor? im makin bout 400hp 425 ft lbs i hope i didnt do any damage with out the lube
1958 belair 2door
Old 12-23-2004, 09:44 AM   #6
da-burb
"Ochre Ogre"
da-burb's Avatar
My understanding on the lube is it helps it slip going around the corners. It would not make it engage in a straight line any better.
Bowtie Truck Stop Inc.
Mid-West GM Truck Restoration Parts Supplier
Your Key Parts, Auto Metal Direct, Dynacorn,
and Goodmark dealer.
like us @ www.facebook.com/BowtieTruckStop
1971 C-10 Suburban (Ochre)
1971 K-10 Suburban (Ochre)
1972 C-10 Suburban (Ochre)
1972 K-20 Suburban (Yellow- that just aint right!)
Springfield, Minnesota 56087
da-burb is offline   Reply With Quote
Old 12-23-2004, 10:04 AM   #7
dons454s
dons454s's Avatar
The addative only makes it slip around the corners if you dont have it in it should feel like it is grabing going around a turn even squeal a little.
dons454s is offline   Reply With Quote
Old 12-23-2004, 11:15 AM   #8
FirstGen
Just Don't Stop!
FirstGen's Avatar
try the lube first. Go get a bottle of GM friction modifier from the dealer. It's the only stuff worth beans. Should cost about 7 bucks. I've had that stuff work wonders on clutch type posi units.
If you are making the kind of power you think you are, don't expect that unit to last long anyway.
1968 C10 build in process
TT LSA/6L90e/9"
FirstGen is offline   Reply With Quote
Old 12-23-2004, 11:36 AM   #9
67ChevyRedneck
67ChevyRedneck's Avatar
That's odd, it should never be locked in a turn, unless your spinning, because technically one wheel is rotating slightly faster than the other in a turn, and if both tires were locked you would hear chirping becuase of something called "wheel hop" It's also the same reason you aren't supposed to drive on pavement with 4x4 units that "lock" it creates this wheel hop and causes damage to the tires and axle. It should be slipping in the corners and gripping when you slam it on a straight away. I'd try the juice, if it don't work, maybe you have a defective unit??? jmho
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
