05-30-2002, 08:45 PM | #1 |
Slowly getting CRSS...
shocks?
all my shocks are basically blown out and its time for some fresh ones. In my quest to thwert the problem on getting the rear tires to hook up i wanted to put the shocks that allow the front of the truck to rise and the rear to squat. who makes some of these for our trucks, i cant seem to find any, all i ever see are the edelbrock shocks in the catalogs.
-Nic Lutz, Fl My Team Website The Heavy Chevy Website ------------------
There is No replacement for Displacement... "If everything seems under control, you're just not going fast enough." - Mario Andretti |
05-30-2002, 08:50 PM | #2 |
I need another Barley Pop
67 Short Fleet 4x4 04 Honda CRF450R 89 Toyota 4-Runner 34 Ford 2 door sedan - Long term project ---------------------------------------------- There is a very fine line between "hobby" and "mental illness" |
05-31-2002, 11:38 AM | #3 |
I'm not sure, Edelbrock shocks for our trucks are just for 4x4s, Koni or KYB might have them.
1942 Master Deluxe 1969 C/10 1985 Blazer CUCV 1987 Jimmy 2004 Tahoe 2005 Silverado 1500 2005 Silverado 3500 |
05-31-2002, 12:00 PM | #4 |
IMO, springs are way more important in the suspension tuning process than shocks. I would replace yours with a new hydraulic shock and investigate some light duty springs from the rear. I like the Pro Comp shocks by Explorer, just get the 1000 series. I'm not sure if you could use El Camino/Chevelle springs or full size car springs. This will kill your load carrying capability however. Summit has a drag shock as well as Competition Engineering if you do decide that route.
05-31-2002, 01:25 PM | #5 |
You can get 90/10 shocks from Summit, but from what I read they are pretty scary on the street.
'69 CST Short fleetside Lowered, 400 small block, 700R4, 4 wheel disc brakes, front sway bar & rear camaro sway bar (in progress) '87 V10 4x4 Short Fleetside Quad Suspension and Dual Tanks |
