Old 03-01-2005, 10:39 AM   #1
1986Silverado
What I drive
1986Silverado's Avatar
Anybody got a pic of some 15x10 wheels running........
255/70/15 tires? Wondering if it would look good to run 15x8's up front with the 255/70/15 and 15x10's in the rear with 255/70/15s?
1986 Chevy Crew Cab Dually(Choo-Choo Conversion)
2006 Chevy Equinox
1986Silverado is offline   Reply With Quote
Old 03-01-2005, 11:48 AM   #2
60-66 Nut
Professional Beer Tester
255/70R15's will work on 10" wheels, but personally I like the looks of 275/60R15's on 10" wheels. They're the same height as a 235/75R15 but a little wider than the 255/70R15. But then again, I'm an oldie. Just my 2 cents.
60-66 Nut
60 Ford F100 Custom Cab
61 Apache Short Fleetside
64 C10 Short Stepside
65 C80 409 V8 5spd(X-Firetruck)
83 GMC 350 Olds Diesel
85 GMC Short Bed
86 GMC Short Bed
90 GMC R3500 Crew Cab
92 GMC 1500
60-66 Nut is offline   Reply With Quote
Old 03-01-2005, 12:00 PM   #3
Jonboy
Slots go on anything!
I think if you put the same size tire on a wider rim, it will have a shorter installed height. The wider rim (rear) will be shorter than the front.
1974 Jimmy- 5.3/4L80e/NP241
Jonboy is offline   Reply With Quote
Old 03-01-2005, 11:02 PM   #4
75stepside
*Proud Member*
75stepside's Avatar
i think i'm going with dunlop's GT qualifier - 295/50/15 in the rear and 235/60/15 up front... about the same size tires...
check out this link - a great way to check tire measurements.
http://www.tirerack.com/tires/Spec.j...omCompare1=yes
75stepside is offline   Reply With Quote
Old 03-05-2005, 01:02 PM   #5
pedrofixlater
75 STEPSIDE
pedrofixlater's Avatar
I was thinking of a 295/50 15 vice a 275/60 15 but the 50 is an inch + shorter in diameter but is an inch wider still maybe 295/50 on back and 245/60 on front.
I'm old school also
Pete
75 Chevy Stepside
70 Buick Skylark/GS
pedrofixlater is offline   Reply With Quote
